Problem for Hard Drives
Generic problem for all Hard Drives
Samsung sata hard disk detection pro...
i m trying to install (genuine) windows sp2 on my samsung sata hard disk but while setup hard disk is not detected by setup .what is the problem .if it needs driver to detect then where i will get that drivers i mean on which site i can get them .
pls help me .
Same Problem
Jan 03, 2009
-   I have a similar problem...
Bios see's the SATA, Windows see's the SATA, but Windows XP Setup doesn't. I have Windows installed on an old 20 GB IDE drive(drive C).
I've added a 160 GB drive(SATA) to my machine(drive E). I now want to remove the old one and install Windows XP on the new one..................
Any suggestions would be greatfully appreciated.
-   Guest Dec 06, 2008
-   I can't install windows xp on my laptop and i'm suspecting that the hard drive is not compartible with windows XP installation because the harddrive is SATA and i know that Windows xp can not install on SATA without having the appropriate drivers. My hard drive model is Samsung HM121HI.Please i need help.
iykon Aug 15, 2008
-   I got the same problem with you too.but I have another problem is my mother board does not support raid.
windows setup do nothing (didn't run)after the bios booted,the bios
agent told no hdd has been detected,if so,how could I install when bios
can't detect my samsung hdd?
on9666 Aug 15, 2008
windows setup do nothing (didn't run)after the bios booted,the bios agent told no hdd has been detected,if so,how could I install when bios can't detect my samsung hdd?
on9666 May 17, 2008
-   none yet
-   Guest
Best Solution
posted on May 31, 2008
Rank: Apprentice
Rating: 99%, 6 votes
Check your BIOS. There's a setting there to change the Drive controller which allows the SATA drive to be recognized. I believe when I did it I had to change the RAID setting (even though I wasn't using RAID).
Was this helpful?2 people thought this was helpful
Solution #2
posted on Sep 23, 2007
Rank: Guru
Expert
Rating: 88%, 3870 votes
Typically, Windows XP installer does not provide full support for SATA HDs (drives) nor for all kinds of SATA Controllers (on the motherboard or add-on card).
However, Windows XP installer provided a way out by prompting the user to press F6 and load the necessary drivers in the FDD. The diskette containing the drivers may either come from: manufacturer of motherboard; manufacturer of controller; or manufacturer of HD.
If none was provided nor available, then perhaps you can DIY (do-it-yourself). More often than not, it is inside the MB installer/driver CD in D:\Drivers\SATA or something like that and copy to a floppy diskette. Alternately, you can download from the manufacturer's website, decompress and copy to FD.
When the Windows XP installation CD puts out the message "Press F6 if you need to install a third party SCSI or RAID driver", press "F6" as instructed. Thereafter, press "S" to specify additional device on the next pop up screen. Insert the driver floppy disk in and press enter to continue. If the floppy disk is made
successfully, the installation program will ask for selecting driver. Please then select "Motherboard chipset (VIA, Intel etc Serial ATA RAID Controller(Windows XP)".) After the SATA driver loaded, Windows XP will now recognize the
SATA HDD, proceed and continue to install Windows XP.
If you do not have a FDD, one of your option is to DIY a slipstream WinXP installer CD. This is better explained in this article <http://www.maximumpc.com/article/How-To--Slipstream-your-XP-installation>.
Hope this be of some idea/help. Pls post back how things turned up or should you need fur4ther information.
Good luck and kind regards.
Was this helpful?3 people thought this was helpful
Solution #3
posted on Oct 09, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
If you have AHCI turned on in the bios turn it off and switch it too ATA...
Popular Solutions for Hard Drives
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB...
3 Solutions
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA,...
1 Solution
Western Digital My Book Essential Edition (WDG1U5000N) 500...
1 Solution
Western Digital WD Passport 250GB Portable Drive 250 GB Hard...
1 Solution
Questions and Unsolved Problems for Hard Drives
I own a Western Digital 250 GB MyBook external HDD. This has worked well for a number of years and...
(More)
I own a Western Digital 250 GB MyBook external HDD. This has worked well for a number of years and contains a lot of precious data. A few days ago I stopped being able to access this drive. The LED on teh drive now flashes rhythmically (didn't do this before). I can still see the drive in device manager and in disk management so it is definitely getting power but I cannot see it in my computer. I have tried hooking it up to another computer, using a different USB cable and taking the drive apart and using a different IDE connection but with no results. Help please!
(More)
My WD MyBook Essential 500GB loses it connection and disconnects from my iMac. When this happens I...
(More)
My WD MyBook Essential 500GB loses it connection and disconnects from my iMac. When this happens I notice that I also lose use of my USB ports on my mac keyboard. If I disconnect the USB drive and restart my computer, the USB ports on the keyboard function just fine. If I then start the computer with the WD HD attached, it starts fine and I can access files stored on it.
drive does not show up on my computer. How do i see the drive. It is plugged into power and to a usb...
(More)
drive does not show up on my computer. How do i see the drive. It is plugged into power and to a usb port
I have a 500gb Hitachi sata drive on a gigabyte GA-Ma78gm-s2h mb that ramdomly goes offline. Takes...
(More)
I have a 500gb Hitachi sata drive on a gigabyte GA-Ma78gm-s2h mb that ramdomly goes offline. Takes shutting down computer and restarting to bring back on line
