Question about JVC RM-RL1 Remote Control
Television is not responding properly to the remote
The remote turns the television on and off it will even allow the tv to switch from dvd, vcr, and cable. But when we push the play button for the vcr it will not respond
  • 371 Answers
You need a brand new one of THESE and they are priced from 10.95 to 39.95 or less than the bench time to "fix" the vcr button on your remote, and since remotes are always coming up missing, you will
have a spare for all functions except the vcr and a basis of comparison for future troubleshooting processes as other functions fail, if any such failure should occur.
Posted on Apr 21, 2009
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Sep 26, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
I have a Panasonic DVD/VCR TV. The remote control works intermittently. Sometimes I can control the volume and DVD/VCR using the remote and sometimes the TV does not respond to the remote. I spoke with...
Do you still have the instruction booklet for the Tv? Find the remote codes and try re-programming the remote. If this still happens try programming an after market universal remote. Hope this helps.
Sep 12, 2009 | Panasonic Televison & Video
I need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Mar 26, 2009 | Televison & Video
Sony MW24FM1 either won't respond to DVD commands, or turn-off
Sounds like a bad power board. They have random meltdowns all too often. Usually the cause is an overheated transformer caused by power transistor short outs. Possibly sell it. Could get over $100 for it if sold online.
Nov 14, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Directv universal remote
ok i have a sylvania tv/vcr combo, similar problem, here's how i got the directv remote (RC23 & RC32) to operate basic t.v. functions:
-First i found the code that worked for the vcr (20000 in my case).
-i programmed "AV1" to 20000, this allowed me to power the tv on/off, change the channels but not operate the volume, so...
-after plugging in the 20000 code (with the slelector switch on AV1 still):
1. Press and hold the MUTE and SELECT keys until the
green light under the TV position flashes twice, then
release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press select
that allowed me to operate the t.v. volume from the remote w/ the selector switch in any position, the only thing is i have to switch to AV1 in order to power off the T.v.
hope this helps in your case
Jan 31, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
Hitachi TV
If your remote transmitter is multifunction, such sa TV; DVD; and VCR operative; You may be in the wrong mode. Press the TV function first and then try to change the volume. If you still have problems, the remote may be defective.
Nov 15, 2007 | Televison & Video
JVC RM-RL1 Remote Control Logo
147 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
