Question about Kitchen Appliances - Others
Pitco fryer sg14R not turn on at all
Checked the gas supply , checked the power everything look good but it doesnt light the pilot even the lid lights not working
    Scholar:
  • 81 Answers
The hi limit must be tripped. Open the door and find a swich that has a really small red button on it and push it in. If it clicks, it was tripped. If not, with the door open bend way down and look up whare the top of the door is when closed. You will find a small black fuse holder. Push up as you turn, and pull out. Check to see if the fuse is blown, if it is replace with the SAME SIZE & RATING. DO NOT USE TIN FOIL.
Posted on Jul 25, 2009
Pitco fryer
Hi there!
Try to check first the incoming and running gas pressure, it must comply with the rating on the unit's nameplate.
Regards
Jan 26, 2013 | Pitco Frialator Kitchen Appliances -...
Pilot won't light at all on Pitco Frialator.
Would not be a good plan to do this your self gas valve replacement is a gas fitters job
May 25, 2012 | Pitco Frialator 35CS Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
.poilit light on but not burnner on even i turn
Check if the gas valve knob is set at "ON" position after lighting the pilot. Check also it the thermopile is receiving enough heat from pilot flame and try also to tighten all wiring connections on gas valve, thermostat and hi limit. If these do not seem to correct the problem, you have to replace the thermopile.
Feb 28, 2011 | Pitco Frialator SG14 Deep Fryer
Pilot light works but gas wont turn on.with temp guage turned up?
Check if you have turned the gas valve knob to "on" position after lighting up the pilot. If so check for the continuity of the thermostat terminals using an ohm meter. If the thermostat is good, try replacing the thermopile, if it does not correct the problem, try replacing the gas valve. Make sure that the unit receives sufficient gas pressure and volume before doing part replacements.
Feb 05, 2011 | Pitco Frialator SG14 Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
Pitco old gas fryer pilot light outage, change the themocouple,still won't work
Check and tighten all wiring connections. check if your thermopile receives enough heat from the pilot flame. Once the pilot is lit, the hi limit device will be the only one capable of shutting it down during operation (once the oil temperature reaches 450F) provided the gas supply is sufficient.
Nov 27, 2010 | Kitchen Appliances - Others
Pilot stays lit but when you turn on temp switch pilot gets very low and burners will not light
has orifice been changed? Is this a used fryer that may have previously operated on LP gas? If so, there will be insufficient volume of gas (Nat) to the burner. Also check supply pressure at unit. Make sure supply line isn't damaged or distorted in that it may restrict flow to fryer.
Nov 19, 2010 | Pitco Frialator SG14 Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
253 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
