Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Computer says no files on device
On my replacement sansa c250, the computer lets me load files on the player only when I format, and thus lose everything that is there already. I can not view the files on the Sansa on my computer. Could computer be confusing my new player with the returned player as I do not know how to delete the previous Sansa? Neither the computer nor the player recognize my Micro Sd card that worked in the previous sansa and has 1gb of music installed I have removed the sd card but that did not help.The player will not sync except in format. I use wma 11
Open device manager under the Control Panel to view hardware and devices. There should be a tab under portable devices that recognizes the Sansa c250. If their is a yellow exclamation point, then most likely the device has stopped working. Right click on it, and uninstall the device. Unplug your Sansa, wait a couple seconds, then plug it back in. Let it do its thing. If this does not solve your problem, then you should deffinately call the manufacturer.
Posted on Sep 23, 2007
SOURCE:
Scan disk sansa c200 series locked with an error message
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Deleting
-Tha Mp3 Doctor
Mar 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Music transferred from internet to my sansa not good
Am not sure which of the 2 actions we did solved the problem...but we installed the CD that came with it (my daughter has a Sansa C260 and her CD was already installed in the computer and we thought I didn't have to install mine). But we resorted on installing mine too in case it would help with the problem, and then we re-loaded all the songs into my Sansa C250 at a slower pace, although I really don't know if the quicker pace did cause the problem. But now my Sansa C250 is now able to record any song correctly.
Mar 15, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 freezes while refreshing database
I got my c250 to turn off while frozen by holding the "menu" and "select" buttons down at the same time for a few seconds.
Jan 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Reformatting songs/mp3 player
The Sandisk site says that your dad's device should play .wav, .mp3 and .wma files. Has the player EVER worked? I got a C250 for my wife as a Christmas present and my computer recognized but refused to communicate with it UNTIL I DOWNLOADED AND INSTALLED THE FIRMWARE UPDATE. The player was a paperweight until then. It turned on and played the demo files pre-loaded on it, but I couldn't transfer a single file into it. Just a thought. Here's the link:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
good luck.
groove_guy
Jan 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Dec 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can't delete songs off my MP3 (sansa c250 2G)
You should format the device thru My Computer>Device Name (c250)>Right Click and select FORMAT.
Best of Luck.
Nov 07, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can't erase songs
THE ONLY HELP THAT I CAN GIVE YOU IS TO CALL THE COMPANY HERE IS THERE NUMBER Contact Customer Support at 1(866)SAN.DISK
Aug 11, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
HELP ME PLZ
That's a pretty weird problem. The only suggestion I can give you is to check to make sure the music you put on was 1) in mp3 or wav format and 2) if this is music you have purchased, to ensure you have the rights properly set to play the music
Aug 06, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa C250- accidentally formatted using MAC
ITS RELATIVELY DIFFICULT TO REFORMAT THE DEVICE NOW INSTALL THE SOFTWARE FULLY INTO AN WINDOS OS THEN CLICK OPEN THE EXPLORING TOOL FOR YOU MP3 PLAYER WHICH IS BUNDLED UP ON YOU SOFTWARE CD AND LOOK FOR ANY BUTTON SHOWING BROWSE MY PLAYER AND CHECK FOR THE INITIALIZE OR FORMAT PLAYER UTTON THIS WILL DO THE TRICK ONE QUESTION TO CAN YOU STILL COPY FILES TO THE PLAYER
Jul 12, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
171 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
