External drive power supply 3 wire code???
I have a power supply adapter for an external hard drive. input: 100-240vac, 50/60Hz. output: 12V = 2A, 5V = 2A. i would like to splice the 3 wires, red, yellow and white to another power adapter (the old one is broken)but don't know what each wire represents?
  • 4,806 Answers
Hi there.
Have a look at this link for wiring instructions >>>>>
http://www.pc-user.co.uk/power_connectors.htm
Hope this helps and thanks for using FixYa!!
Posted on Apr 21, 2009
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Will not power on
WELCOME TO FIX YA
i hope you didn't dropped it cause dropping it may cause to malfunction or no function at all
here are some steps you might follow if its not broken it may work
1. first of all check the adapter if it says Input:100V-240V~50/60Hz Output:5V/2A; 12V/2A ,
if you have the original adapter check for the values
2. if it doesn't powers your external drive then check for a adapter of same inputs and outputs
see if it works with another adapter,go to a shop and ask someone that you want to check ,
if it works then you have to buy it.cause our adapter is out.
if it doesn't your final procedure should be this
1. install driver from here
2. install it .and see if it detects the drive works.
now if it doesn't help ignore this post .cause i don't want to reffer you to a service center,cause i consider this as a help to you.
Best Regards
do tell me that how did you resolved the matter ....!??
Apr 06, 2011 | Masscool UHB358B Aluminum 35' USB 20...
Can you please provide me the power adapter specs? I need to buy a new one.
I found This power supply
It is listed as suitable for the Porsch drives, but the model number on your current unit should tell if it's the right one.
At 12V 3A it is rated higher than the common 12V 2A which is a common rating for hard drive power adapters, and also supplies 5V. These may be required for your drive.
The site has other LaCie power adapters if the model number does not match.
Feb 09, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Second time this has happened, Apricorn ez bus dts power supply
You can use a universal Adapter.
All you need to do is to match the correct voltage and the correct Ampere.
Lets say for example the input of your adapter is : 100-240v, 50,60hz . and 0.5 A
the output is : 12vor 5v 2A
So check this that correspond to the one you already have.
But one thing :: don't use one that is of a higher voltage capacity.
It will burst out forever the disk........
If you need any further help please let me know.
Regards
Uttam
Jan 29, 2010 | Apricorn EZ Bus DTS (EZ-BUS-DTS-500e) 500...
External Hard Drive - Beyond Micro
I have the same BMMDU2. It's used 12V/1.5A power suply.
May 11, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Unusual Power Requirement
Should not be a problem, the theory here is Volts * Amps =Watts
5V * 2A = 10w
The alternative is to get a LM7505 ($1 or 2) from radioshack or any electronic supply and regulate the 12v down to 5v. its about 1/2 square IC chip.
Pardon my ASCII:
[_]
input 1.7V - 35V ________| | |_____ +5v (+/- 1%)
Pin 1 Pin 3
will accomodate 1 Amp (1.25 if heat sinked) for the CMOS version, slightly higher for the olde r(less effecient) version
The other pin is ground. OF course you will want to check the specs and pin assignment for the brand you buy, these are typical.
TechieJon
Apr 18, 2009 | Computers & Internet
Power Pin-out?
I have built an adapter cable which allows to use monitor with the power supply of an external hard drive. The image below contains the pin-out for the power connector of the L50A as well as the wiring scheme for the adapter cable.
For users in Germany, here is the list of complete part list with prices:
  1. Universal Power Supply 12V 2A DC and 5V 2A DC, 13.20€
  2. 6-Pin Mini-DIN Male, 0.71€
  3. 6-Pin Mini-DIN Female, 0,71€
  4. 5m 6-Wire Cable, 2.80€
Have fun, Wolfgang.
Nov 27, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
WD hd won't start up when turned on until you plug into usb
i cant put a solution for this but try the exact software for the disk which it came with this can help.Im also trying for the software
Oct 27, 2008 | Western Digital (WD3200JS) 320 GB Hard...
MY COMPUTER JUST STOPEED AND I NEED 2 KNOW THE SPECIFACAITIONS ON THE POWER SUPPLY
If you are using latest system you need
Ac input : 220vac 3a 50hz
450watt minimum
Atx 2.03
Atx 12v
Dc output
+5v 28a -5v 0.6a
+12v 15a -12v 0.6a
+3.3v 16a +5vsb 2a
Apr 16, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
