Question about ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI (t2-p)
Shuts off every 5 minutes after being turned on...
My ASUS T2-P keeps shutting off on me. Is there a correction for this?
Well, I actually figured out what was wrong with mine.  It was actually my hard drive which was causing the reboot. It was still under warranty, so I had it replaced.
Posted on Oct 12, 2007
SOURCE:
Gas dryer starts to heat but shuts off while drum continues but doesn't heat or dry
Check your safety switchs ie; limit stat, flame sensor, thermostat and see if their all functioning properly. If they are check your gas supply and make sure the correct gas pressure is getting through.
Sep 19, 2013 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Trane xe1200 compressor fan motor only runs for about five minutes
Than it's not wired correctly. Did you splice the motor wires? Black on left, common to cap which should be the right from contactor and fan which I think, without looking, is brown. purple common...
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 17, 2018 | Heating & Cooling
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
TV turns on for about 5 minutes then shuts off.
The projection lamp is out and needs to be replaced.
Jan 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Have power cord plugged into asus eee machine and wall outlet. light has been blinking all day. when asus eee gets unplugged it shuts off.
lets try this ---
* turn of your computer
* remove the plug from your computer.
* Remove the battery from your computer
* Let it sit for 3-5 minutes
* Replace the battery
* Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
* Let it sit for about 3-5 minutes
* Boot your computer
* go to
Start -> Control Panel -> Power Options -> Power Meter
Note the Total Battery Power Remaining
* Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
If so problem solved
if not you may be time for a new battery.
Dec 26, 2008 | Computers & Internet
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Sound problems
You must use the camera mate disk video disk and have it installed because the disk has the drivers on it!
Oct 30, 2007 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI (t2-p) Logo
62 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
B.Th. Pluijm
B.Th. Pluijm
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
