Question about Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher
Dishwasher just draines and nothing else??
I have a Hotpiont BC1450 built in dishwasher but its just started to go wrong, when i start it up and put it on either of the two wash programes besides eco wash all it seems to do is constantly drain the water out, doesn't start a wash cycle just keeps draining it also switches the programe on to eco wash, can anyone help??
  • Anonymous Jan 16, 2008
    How do you gain access to the underneath?
  • 209 Answers
This sounds like it could be the heater element has gone faulty, it is quite difficult to get to test it with it being built in, but basically gain access to the underneath of the appliance and you can test it with a test meter for open circuit, it is also possible that a wire has either come off or broken, the pump pumping out is like a safety mechanism, the eco wash may work because this uses no heat? (some models) the answer i have given you is based on the info you have supplied if i have helped please rate me, thank you, please work safe unplug when working on appliances
Posted on Sep 22, 2007
Set my dishwasher on the wrong program pressed the start button then change mind it was on the wrong setting switch of changed setting now will not start
Try throw the breaker off for 15 min then back on. That may clear the program. If not restart it on the "wrong" cycle and let it finish out.
Feb 19, 2015 | Whirlpool GU2400XTP Built-in Dishwasher
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
Dec 30, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
When I turn on the dishwasher, the light on program 6 flashes but the program will not start.
Pull the power plug or turn off the circuit breaker for about 30 seconds, plug it back in or turn the breaker on and the diswasher brain should have reset. Good Luck.
Dec 14, 2017 | Smeg 24 in. DWI612 Built-in Dishwasher
Hotpoint BC1450 Light 2 normal flashes
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Oct 07, 2012 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
My dishwasher won't drain. I have tried to start it and there is power, but nothing happens.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 19, 2010 | Frigidaire PLDB998A Built-in Dishwasher
I am house sitting,and have forgotten instructions on how to start my daughter's dishwasher. I have been unable to reach her, since she is traveling,
open the tap for the water inlet, put all the dishes after removing off the waste food, arrange in order accordingly.
now choose a normal wash program and press start.
Sep 19, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Kitchen aid dishwasher not draining....help
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Washing tablet found unused on the bottom of the dishwasher...
Put the tablet in the bottom of the washer ,do a wash cycle,if the tablet is used up the washer is not releasing the tablet till the end of the wash, if the tablet is still there the water is too hard or the tablet is faulty.
Nov 29, 2017 | KitchenAid KUDK03ITBK Built-in Dishwasher
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
490 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
