Water inlet always open
The cold water inlet is always open, the hot is not. Should it be? By reading other problems seems like I need to get a new inlet? Thanks all!
    Sniper:
  • 88 Answers
If you mean "always" as in, it fills with water when the machine is shut off, then yes, you definitely need a new valve.
Posted on Apr 21, 2009
Asko front loader fills with water when switched off and once turned on will immediately sense it and drain it from the machine. What could be the problem? The machine still washes beautifully, even after...
inlet valves are out of service or malfunctionnign follow the steps .
1. unplug your machine power cord.
2. open the door and also open water supply , if your machine fills the water then 100 % problem is with your inlet valves , replace it , simple
regards
Dec 31, 2014 | Asko W6021 Front Load Washer
IE error on wd1484adp
LG's 'IE' stands for '(water) Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB
Jun 15, 2012 | LG Wd-1484adp 8/4kg White Direct Drive...
Can i run new hot water return line back to hot water system
Open following link to view how recirculation system looks:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Ordinarily the cold water line is used to complete recirculation loop.
There is no reason why you cannot run separate line back to water heater instead of using cold water line.
The Grundfos system comes with crossover piece that connects hot-and-cold lines at furthest faucet.
Instead of connecting between hot-and-cold line, simply connect hot to your new hot water return line.
When your new line arrives back at water heater, it must connect to cold water inlet so return water is directed to bottom of water heater.
For critical safety concerns, do not remove TP valve to install new water inlet.
Nor is it best to use extra plug on top of tank to install new water inlet, unless you also install dip tube that directs water to bottom of tank.
http://waterheatertimer.org/How-it-works.html
In the case of tankless water heater, return line must be connected to cold water inlet also.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
I have a samsung sw52asp top loader ..it fills but wont switch off water and go into wash cycle it just overflows...help
  1. It sounds like your Water Inlet Control Valve may be getting stuck, or is stuck. There are 2 water inlet control valves, 1 for hot water and 1 for cold water. Does this problem happen when using the hot water only, or cold water only? You will need to replace the water inlet control valve for the side that is stuck open.
  2. If this problem happens with hot water and cold water, you may have a faulty control board, which will need to be replaced.
Mar 01, 2011 | Washing Machines
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WDD960 Washing Machine - Hot and Cold water inlets. I set my machine up originally with the Y piece, but thought using the hot inlet would be more economical so I have fitted separate hoses. ...
Do you have the hoses on right. Coming from the water supply which you should have two cut offs,looking at them the left one would be the hot line and right cold. Make sure they are hooked up this way on washer and see if you get hot water. If they are hooked up right then either your hot side of the water inlet valve isn't opening or the control board isn't telling it to open.
Sep 15, 2009 | Washing Machines
Kenmore h3 Elite Hot/Cold Water problems
I wouldn't imagine it being a computer problem, computers don't make mistakes like that. I would start with the inlet valve http://www.partselect.com/xq/aspx/Inventory.391478/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 and maybe the inlet valve wiring harness http://www.partselect.com/xq/aspx/Inventory.391563/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 for good measure. Both parts together will run you less than $100 and shouldn't be that difficult to replace. I'm am no Washing Machine expert, I just go by my common sense and Google. The computer http://www.partselect.com/xq/aspx/Inventory.971890/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 is $250+ and like I said I don't think the computer would cause the valve to open slowly and stay open, sounds like the vavle is sticking. Good Luck!
Apr 14, 2008 | Kenmore Elite 45986 Front Load Washer
NO COLD WATER
the problem sounds like an elecronic faullt try swapping the hoses over and also check that the resistance readings on the valves are the same.some times if they are diffrent it can damage the pcb.hope this helps
Mar 05, 2008 | Washing Machines
No cold water, only hot water in tub
Check first the filters on the cold inlet water line (both sides). Then, if problem is still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Sep 02, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
