Computers & Internet Logo
matt penhall Posted on Oct 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fujitsu S6520 - when i start, the num, caps & scroll lock led's blink 3 times and then the computer dies - the screen stays blank the whole time and then turns itself on again and the 3 led's blink every second for ever!!! the screen stays blank! any ideas? Have tried the battery and RAM tricks...
k24674
Level 3:
  • Fujitsu Master 8,093 Answers
  • Posted on Oct 13, 2013
k24674
Fujitsu Master
Level 3:
Answers
8093
Questions
0
Helped
4675041
Points
21596
You may have memory problems. Memory module(s) may be defective or not seated correctly in place. Check the memory modules first. It seems that you have already checked the RAM modules.
Connect the computer to a monitor and reboot to see if anything is displayed on external monitor.
3 Related Answers
Anonymous
  • 114 Answers
  • Posted on Jun 10, 2008
SOURCE: startup problem
that wouldn't mean the processor is off, it means there is a problem with the motherboard. I don't know the exact problem with the motherboard. but it could be something wrong with the processor too. but I suggest you take your PC to like Circuit city, best buy, or your local computer shop to have them take a look at.
Anonymous
  • 324 Answers
  • Posted on Mar 09, 2011
SOURCE: cannot power on only led light
Welcome to fixya, This could be a number of issues.
It could be your ram chips need to be replaced, it could be your battery.
Try this to narrow it down.
Remove the power cord, and the battery.
Press and hold the power button for 30 seconds solid.
Then, do not put the battery back in, just the power cord.
Try to start the computer, if it starts, your battery is failing.
If it does not start, leave the battery out, remove the power cord.
Turn the laptop upside down and remove and reinsert the ram chips.
Then, plug the power cord back in and try and start it again.
If it starts, your ram chips may be failing and you should think about replacing them.
KittyTech..
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Anonymous
  • 53 Answers
  • Posted on May 22, 2011
SOURCE: I hit the power switch
your pc is going into sleep mode instead of fully shutting off. Use the start>shutdown in windows to ensure full shutdown
Fujitsu Laptop. Pls Help for my laptop that turns on with no display and only blinking num lock light.
Question edited for proper spelling of maker name and better English.
Question moved to Fujitsu category.
No model, service tag details given, so generic help.
Re: E744 - NumLock flashing Remove the battery and the ac adapter and press the power button again for a view seconds. After that connect the ac adapter first an try again if you can start your device. If you are facing the same problem again you should contact a service partner regarding a repair of your notebook.
May 5, 2015
E744 - NumLock flashing - Fujitsu Support Forum
Fujitsu https://forum.ts.fujitsu.com > forum > viewtopic
Fujitsu S6520 screen blank with Num lock blinking
Fixya https://www.fixya.com > support > t5988599-fujitsu_s...
Press and hold the power button for 30 seconds solid. Then, do not put the battery back in, just the power cord. Try to start the computer, if it starts, ...
tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 • Computers & Internet
Fujitsu lifebook s6520 is not comes ON when i press the power button the lifebook comes ON its all LEDs & processor fan sound is listened but then just NUMLOCK led starts blinking after that blinking...
Is the monitor working. If have not checked it try connect it to an external screen. If the screen is okay, try and remove memory (RAM) and after ten seconds you place it backup and start the computer and check.
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
2helpful
Cannot power on only led light (num lock,scroll lock,cap lock) flashing Model: S6520
KittyTech..
23helpful
4answers
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
18helpful
4answers
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
Blink: 3 - Caps Lock/Num Lock
Memory
Blink: 4 - Caps Lock/Num Lock
Graphics
Blink: 5 - Caps Lock/Num Lock
System board
Blink: 6 - Caps Lock/Num Lock
BIOS
7helpful
2answers
BLINKING Num Lock, Caps Lock & Scroll Lock
Put the RAM back in or check the RAM in securely
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
