Pulled device out wrong from computer i have an ipod nano
  • Mel Neilsen
    Mel Neilsen May 11, 2010
    Have you tried to reset the ipod by pressing both the menu and center buttons for about 10 seconds or until an apple appears on the screen? And did you disconnect it while it said do not disconnect? Or did you kinda yank the USB cable out?
  • 342 Answers
Here is some more in depth trouble shooting options available for iopds.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
I hope this is helpful
Posted on Apr 24, 2009
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
I have a 8g ipod nano model number a1199 and i got it awhile back and i lost it. recently i found it and forgot the password. is there anyway i could reset the whole ipod... or whatelce could i do?
The latest iPod Nano includes a locking feature, which allow users to set a four-digit combination to keep intruders from using the device. However, if you find that you forget what code you set on your iPod, you will need an alternate way of unlocking your iPod Nano. Once the device has been successfully unlocked, you can continue listening to music on it.
Plug the iPod USB cable into the bottom of the iPod Nano. Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. Click on the name of your iPod Nano under the "Devices" list in the iTunes window. Click on the "Sync" button to establish a connection between your iPod and the computer. Click on the eject symbol next to your iPod's name after the syncing process has finished. Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again. Hope it helps.
Jan 23, 2013 | Apple A1199 ipod nano
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
IPOD NANO 8 G is locked. How do I unlock?
  • Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
  • Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
  • Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
  • Click on the "Sync" button to establish a connection between your iPod and the computer.
  • Click on the eject symbol next to your iPod's name after the syncing process has finished.
  • Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
    WARNING
    To unlock your iPod Nano, you must connect the device to the computer it has been previously synced with.
    Sep 28, 2009 | Apple iPod nano
    How do i put movies or videos in my ipod 4GB?????? plz
    only 3rd generation iPod nanos can play video, and the video must be mp4, you can use itunes to sync video to ipod nano, just follow those steps:
    1. Open iTunes and click "File" to add your videos to iTunes library.
    2. plug in your iPod Nano to computer, then iTunes will detect your iPod Nano as a device.
    3. Select your iPod Nano device on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply"
    Jul 22, 2009 | Apple iPod nano
    I need i pod unlok code
    First, make sure the hold switch on the top of the Nano wasn't activated. If not, then:
    You can unlock the iPod nano screen in two ways:
    A Enter the combination on iPod nano by using the Click Wheel to select the numbers
    and pressing the Center button to confirm them. If you enter the wrong
    combination, it flashes red. Try again.
    A Connect iPod nano to the primary computer you use it with, and iPod nano
    automatically unlocks.
    Note: If you try these methods and you still can’t unlock iPod nano, you can restore
    iPod nano. See “Updating and Restoring iPod nano Software” on page 50.
    Jan 27, 2009 | Apple iPod nano
    Locked ipod
    You can unlock your iPod nano in two ways:
    Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
    iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
    information.
    Aug 23, 2008 | Apple iPod nano
    Ipod
    information.
    Aug 08, 2008 | Apple iPod nano
    I for got my code and cant unlock
    â Enter the combination on iPod nano by using the Click Wheel to select the numbers
    â Connect iPod nano to the primary computer you use it with, and iPod nano
    information.
    Jun 25, 2008 | Apple iPod nano
    Registering & Syncing Ipod Nano 3G
    try reformatting the ipod. that might reset it.
    Dec 20, 2007 | Apple iPod nano 3rd Generation
    147 people viewed this question
     Grubhead
    Grubhead
