Question about Brother MFC-5490CN Flatbed Inkjet All-in-One Printer
Getting unable to scan AF message on brother 5890cn
Was in preview, went to import and it started to scan, couldn't cancel, it sounds very noisy and I can't get rid of the message
  • Anonymous Apr 27, 2009
    when i want to scan it says unable to scan AF
Mix-it-up
  • 832 Answers
SOURCE: init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
komguy
  • 2306 Answers
SOURCE: how to hook up phone lines? on Brother MFC-5890CN
The phone line goes to the plug marked L or line, the one with the picture of a phone is for an answer machine.
Posted on Jan 30, 2010
Patzky
  • 240 Answers
SOURCE: Have MFC 5890CN Brother. How can I scan legal documents?
To scan legal documents you need to set the scanner to legal. GO to Start menu / all programs / brother / scanner utility and set the size to legal.
Thanks,
Pat
Posted on May 12, 2010
How do I get rid of outlook preview
It depends what version of Outlook you are using. Here are the instructions for Outlook 2013:
Here's how to disable Message Preview in Outlook 2013 in four easy steps.
  1. Click View on the navigation panel to open up the View tab.
  2. Click Message Preview right below the View tab.
  3. Select Off from the dropdown list of options.
  4. Click This Folder to turn off message previews in your current inbox.
Feb 12, 2016 | Microsoft Computers & Internet
Error 2200
The Downloaded software may not have the Lexmark Imaging Studio on the downloaded drivers....
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Please try the above mentioned steps and let me know what happens?
Feb 22, 2013 | Lexmark P6250 All-In-One InkJet Photo...
When scanning a color picture it comes through in black and white what am i doing wrong?
Change the Options on your HP Scanning Software to Scan in Colour or Else:
Thanku.......
Good Luck!@@!
Sep 23, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    Dec 04, 2010 | HP Officejet 6310 All-In-One InkJet...
    How to scan using hp j4580. Booklet only tells how to fax!!!!
    1. Open HP Solution Center with one of the following methods:
      • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
    3. Use one of the following methods to start the scan:
      • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
      • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
      A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
      2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
      3. Start the scan again.
    4. Read through the various options for the scan settings. Make selections for at least the following items:
      • Scan to: Select your scan destination from the drop-down list.
      • File Type: Select the file type from the drop-down list.
      • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
      • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
    5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
    Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
    Very noisy especially at start up. continual clicking getting worse. I seem to remember some kind of recall message I ignored some months ago.
    Sounds like your harddrive may be starting to fail... Backup all important files while you still can..replacing a hardrive is a pretty inexpensive fix
    Mar 23, 2010 | HP (400745-001) Sound Card
    No Scan Job Checked?
    On my scanner 'microtek i 410' when working in Advanced programme, when i go to 'SCAN TO...' I get this message "No scan Job checked". How can this be remedied?
    Feb 13, 2008 | Microtek ScanMaker s400
    Scanner
    There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
    Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
    Brother MFC-5490CN Flatbed Inkjet All-in-One Printer Logo
    1,236 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
