Question about Garden
Mountfield sp470 petrol mower
Hello
the problem with the mower is that when you prime and start it runs for 3 or 4 seconds then cuts out. If you keep priming the mower is continues to run. Is this problem common and easy to fix?
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
  • 198 Answers
SOURCE: my lawn mower starts easily, then shuts down. each
disassemble the carb and make sure the float valve is not sticking
Posted on May 10, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 2926 Answers
SOURCE: My lawn mower starts, runs for about 5 seconds and
The engine is starving for fuel, that is why it will keep running while you force the fuel to the engine with the primer button. At this point, the carb will have to be removed,disassembled and cleaned. I'm sure you will find blockage and dirt in the carb and also in the small orifices for air and fuel flow.
Posted on May 31, 2010
SOURCE: lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Posted on Jul 06, 2010
What oil do you put in a sp470 mountfield
Hi use SAE 30 in warmer conditions or SAE 10W-30 for varying condition's improves cold weather starting ... Cheers
Sep 06, 2016 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
I have a mountfield sp470 petrol self proppelled lawn mower. the engine is briggs& stratton but i dont know the engine model. i need this as the cylinder head gasket has gone and needs replacing.
Hi. The SP470 has a 4 HP Briggs and Stratton engine.
The part number should be 687171 and you can look here:
http://www.worldofmowers.ltd.uk/Products/ProductList.aspx?search=Head+gasket+&type=3&searchBtton.x=20&searchBtton.y=10
Take a good look at the valve end of the head gasket. From the pictures on the page you should be able to see which one of the 4 head gaskets on the page is yours.
If you have yellow pages you can look up lawn mower repair. Or small engine repair shops. All of them should have this commonly used headgasket in stock. Just find one close to you or.. use the link above.
Here is yet another link for the head gaskets but you have to scroll way way down the page or page search for 698717 or 272171.
http://www.briggsbits.co.uk/acatalog/Horizontal_crankshaft_2-7_HP_Sidevalve_Engines.html
Thanks for choosing FixYa.
Kelly
Sep 12, 2010 | Garden
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Just bought a mountfield sp454 mower filled it with petrol the petrol then started to pour out of fuel bowl there was a plug missing fitted a small bolt in the hole then started the mower it felt as though...
Get he model, type and code off of the engine shroud and take them to your local small engine parts dealer and get the proper bolt for the fuel bowl. They use a special bolt that is hollow and with a weep hole for the gas to flow through the inside of the bolt and up into the carb. Get the right bolt and it will most likely run for you.
good luck
roundo4
May 23, 2010 | Garden
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
May 06, 2009 | Garden
Mountfield sp470
Nov 20, 2008 | Garden
Garden Logo
1,271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
