SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection
is. It is under the easily visible port cover on the top of the
base.
What is NOT easily visible is the connection for the vacuum hose.
That's because the machine needs to be "reconfigured" before the hose
can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight
down. When finished the top should look something like it did in
step 1). This assures that the dirty water will be vacuumed into
the waste water tank.
Done!
SOURCE: Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
SOURCE: Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
SOURCE: hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
SOURCE: Hoover Steamvac hose won't spray water
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
