Question about Radio Communications
How do i turn on my hp windows vista bluetooth raido transmitter
    New Friend:
  • 3 Answers
To turn your bluetooth on do the following process.
1.Click Start , type wireless into the search field, and then select HP Wireless Assistant from the list.
2. By default, the Status column shows that both of the wireless devices are either on (enabled) or off (disabled). Also, by default, the Action column does not display.
If you want to control one of the wireless devices individually, without affecting the other devices, clickProperties , and then select the Independent controls for installed wireless devices option.
If you have removed the HP Wireless Assistant, it can be reinstalled using the Recovery Manager service.
  1. Click Start , type recovery into the search field, and then select Recovery Manger from the list to open HP Recovery Manager.
  2. Select Advanced options .
  3. Select Software program re-installation and then click Next .
  4. When prompted, click Next .
  5. Select HP Wireless Assistant and then click Next .
Follow the on-screen instructions to complete the installation of the HP Wireless Assistant.
You can verify the device is installed & enabled with Windows Mobility Center.
To turn Bluetooth devices on or off, do the following:
  1. Click Start , type mobility into the search field, and then select Windows Mobility Center from the list to open the Windows Mobility Center. Alternately, press the windows key and how do i turn on my hp windows vista bluetooth - c01577398.gifkey at the same time.c01577398.gif
  2. Use the drop-down menu items in the Integrated Wireless Devices selection to turn the devices on or off.
    I think the above tips are helpful to you.
    Thank you for using fixya.
Posted on Dec 23, 2013
SOURCE:
How to input extra audio line for kenwood dpx-410
If it's got bluetooth, you can buy a little aux to bluetooth 3.0 off ebay.
If not it looks like a cassette tape adaptor is worth a shot.
If either one of those don't work fm transmitter is an option, I would stay away from those little ones you plug inot the 12v. Good ones can run you a 50+ and the work in some cars and not others. I would find one that Y's into the antanna at the back of the raido.
Oct 11, 2015 | Kenwood Car Audio & Video
How to enable bluetooth on my hp pavilion dv7
link to driver if not installed alredy
if driver installed :
Check that your PC has a built-in Bluetooth device by consulting its user guide. If it does not, you'll need to buy an external receiver often referred to as a "dongle" and connect it to a spare USB port.
Ensure that your wireless and Bluetooth receiver is turned on. Touch the antenna symbol next to your PC's volume control. It will turn blue when it's on and amber when it's off.
Go to the "Control Panel" from the start menu and select "HP Wireless Assistant" if you're using XP. You'll need to go via "Network and Internet" if you're running Vista or Windows 7.
Make sure your Bluetooth adapter is enabled. If you get a warning that it's not, click on "Windows Device Manager," right-click on your Bluetooth device and select "Enable."
Go back to the "HP Wireless Assistant" window and press the "Turn on" button next to the Bluetooth icon if it's not already showing as being activated. Your Bluetooth device is now on and you're ready to connect to another enabled unit.
Jul 26, 2011 | HP Pavilion dv7-1132nr Notebook PC
I installed window 7 on hp pavilion dv4 1318tu but Bluetooth is not working
Some drivers aren't compatible with windows 7, search your computer specs for the make and model of your bluetooth adapter, go to the HP site and see if you can download drivers for windows vista, if they have them download them to your desktop and right click it and choose to run it as a vista application. This should fix this problem, if they have the software for your device with a vista driver anyway.
Jun 10, 2011 | Computers & Internet
My Bluetooth won't let me turn on Discovery. When I pute a tick in the tick box for ''Allow Bluetooth Devices to find this Computer'' It says ''An error occured while windows was saving your...
you will need the correct bluetooth driver for VISA.
from HP is best.
if HP devices.
if not HP device, you never said bluetooth what, head phones, keyboard, mice, wireless, what? IS IT.
if non HP you need to read the pages of the DEVICE
not stated.
find the vista driver, gee some makers dont support vista...
fact.
Jun 11, 2017 | HP Computers & Internet
Do i have bleutooth?
I went to hp website. It told me that you are supposed to have bluetooth on your system. The following tells you how to verify that you do and how to set it up. All info from hp faq and troubleshooting site. Hope this helps. This document pertains to HP Notebook PCs with Windows Vista. If your computer is using Windows XP , see Setting Up Bluetooth Connections with XP . http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065493&cc=us&lc=en&dlc=en&product=3442075
Sep 13, 2009 | HP Pavilion dv9000z Notebook
Cant install bluetooth drivers on my hp compaq nx 7400 notebook
Which operating system do you have on your computer? Windows XP or Windows Vista?
Windows XP
A detailed troubleshooting page for Bluetooth devices on Windows XP can be found here.
Windows Vista
If you have Windows Vista or that doesn't solve your problem. You can try typing in the name of your Bluetooth device you're trying to connect followed by drivers into google
For example, if I were trying to connect a Microsoft Bluetooth Notebook Mouse 5000 to my computer, I would type the following into Google: Microsoft Bluetooth Notebook Mouse 5000 Drivers
Feb 16, 2009 | HP Computers & Internet
BLUETOOTH DRIVER
If you are using the Preinstalled version of Windows using the Recovery Disks or Recovery partition, you should be having the Bluetooth drivers.
However, you can download the drivers for the Bluetooth Hardware in your Notebook from the links provided below for Vista and XP :
Bluetooth hardware drivers for XP :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34264.exe
Bluetooth hardware drivers for Vista :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34275.exe
Note : If the Notebook is not having a Bluetooth hardware and by installing the Drivers, you may find a Bluetooth icon in the Taskbar and this doesnot mean that you have Bluetooth hardware in the Notebook
Oct 16, 2008 | HP Compaq Presario v3000z Notebook
Bluetooth in HPTx1000
I believe there's a switch on the HP pavilion TX1000 to enable its Wireless LAN and Bluetooth.
To the right of the audio inputs and outputs is a slider switch and an LED. This one controls the wireless devices, both the Wireless LAN and Bluetooth and is blue while the wireless devices are enabled and red when they are not.
If you are using Windows Vista on your computer, you may go click on this link for instructions on how to use bluetooth with Vista.
Using Bluetooth with Vista
Sep 12, 2008 | HP Pavilion tx1000z Notebook
Compaq nX 7400 Bluetooth device not detected by the system and modem drivers not detected
you gotta love vista..did you check nokia's site for the vista 64 bit driver? If you find it post it here, and we'll let the world know about it
Mar 21, 2008 | Computers & Internet
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
