Question about Copystar CS-1510 Copier
Does not feed
At turn on, copier idles , Add Toner lit. Stops idle. Press Start key begins idle and nothing happens...
  • 163 Answers
Please put the new toner cartridge,toner sign will go automatically
Posted on Sep 22, 2007
SOURCE:
Reset drum counter
I found this solution online for you:
Shut off the printer.
  • 2 Hold down the "Continue" button while opening the front door. Then turn on the printer.
  • 3 Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
  • 4 The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
  • 5 Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
  • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
  • 7 Turn the printer off and back on.
  • Mar 27, 2013 | Dell 3100cn Laser Printer
    Reset counter
    By the way, what is the make and model of your printer?
    1. Resetting the Drum Page Counter
      • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
      • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
      • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
      • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
      • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    I hope you find it very helpful. Best regards.
    Aug 16, 2011 | Office Equipment & Supplies
    Replaced toner and waste toner container, but there is still a 'add toner' red light
    1. Press the system menu/counter key.
    2. Select Service setting using the up/down cursor keys.
    3. While pressing the start key and the # key, press the enter key.
    4. Select Maintenance mode using the up/down cursor keys.
    5. Press the enter key.
    6. Enter the maintenance item number (130) using the up/down keys.
    7. Press the enter key. A selection item appears.
    8. Select On using the up/down cursor keys.
    9. Press the enter key.
    10. Turning the power switch off and back on. ADDING TONER is displayed and installation of toner starts.
    11. After approximately 15 minutes, the installation is completed and the machine becomes ready.
    Jan 08, 2011 | Kyocera Copystar CS-1820 Black and White...
    I have replaced the toner and it still flashes u 2 40 and i have tried pressing the # interupt c interupt 16 start but nothing happens....help
    Corrupt or dirty toner unit chip. Remove toner cartridge, if dirty, clean chip and it's receiver on rear of machine. relocate cartridge and reset code using service code # * C * 16 press start key.
    Good luck
    Sep 14, 2010 | Sharp AR-207 Copier
    2004 nissan quest DTC P0507. Can't get IAVL to
    My quest 2004 idle below 500, start up then off, have to start couple times when the engine is cold. when i pushed the gas pedal, it smells gas.
    Oct 21, 2009 | 2004 Nissan Quest
    Replaced drum on Dell 1720dn printer. Where is
    This should fix the drum light being on that 1720
    Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
    May 13, 2009 | Dell 1720dn Laser Printer
    Needs maintenance
    Maintenance doesn't necessarily mean developer replacement, if its working well, ignore developer and continue if it requires, pullout the developer unit and remove the toner hopper. Then empty the used developer and put new one. To empty, turn the dev unit upside down while rotating the magnet roller clockwise the return it in normal position and pour the new developer while turning the magnet roller clockwise until evenly distributed. Put back the toner hopper and screw back and install inside the copier then set it with 'P, Interrupt, C, Interrupt keys enter 25 press Start 2 then Execute key and allow to run till it stops then press Interrupt twice and Press 24 Start 3 Execute . Finally Switch OFF and ON.
    May 07, 2009 | Sharp AR-407 Copier
    1720 Dell Laser printer Photoconductor Problem
    I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
    1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
    2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
    3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
    4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
    5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
    6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
    7) Cycle the power of the printer (turn it off and then back on).
    GOOD LUCK, EVERYONE!!!
    Mar 12, 2009 | Dell 1700n Laser Printer
    First Page printing Jibberish with the Zen thing at the end.
    Try these.
    Reset the Photoconductor Drum Counter
    1. Turn off the power using the switch on the back of the printer.
    2. Open the front door of the printer.
    3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
    4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
    5. Wait till the printer completes the POST process.
    6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
    7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
    Now only the
    8. Cycle the power of the printer.
    - Remove the power cable
    Feb 24, 2009 | Dell 1720dn Laser Printer
    Copystar CS-1510 Copier Logo
    188 people viewed this question
    Top Copystar Office Equipment & Supplies Experts
    Tammie Duggan
    Tammie Duggan
    Adorjani Laszlo
    polytek
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
