Question about Dishwashers
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
I HAVE A MAYTAG MDBO880AWB DISHWASHER ABOUT 4 YEARS OLD. IT LEAKS FROM THE LEFT SIDE OF THE DOOR ONLY SOMETIMES . THE DOOR FROM THE LEFT SIDE LOOKS LIKE IT HAS A BIGGER GAP THEN THE RIGHT SIDE WHEN THE DOOR IS CLOSED. WHEN THE DOOR IS OPEN IT DOES NOT LAY FLAT AS THE SPRING IS VERY STRONG AND LIFTS THE DOOR UP HALF WAY. I NEED TO PULL OUT THE BOTTOM RACK TO KEEP THE DOOR OPEN. I SUSPECT ONE OF MY KIDS LEANED DOWN ON THE DOOR VERY HARD ( OR SAT ON IT) AND POSSIBLY CHANGED THE SPRING SET UP ON THE DOOR HING???? WHICH NOTCH DOES THE SPRING BELONG ON???? ANY HELP WOULD BE APPRECIATED. THANKS
  • petercaruso Apr 27, 2009
    Thanks for the info. When I look at the hing it looks like the hinge sits on a pin . That is my qustion. It looks like there is more then one position. Which slot should the hing be on???
    Scholar:
  • 126 Answers
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Posted on Apr 21, 2009
  • Brent  Reddick
    Brent Reddick Apr 27, 2009
    Best advice without visual on unit is compare to other side and set both same.
My Dishwasher door has suddenly become very heavy, there is a cord hanging down on left hand side its a HJA8630 about 5 years old can you help
The cord you refer to is part of the door spring assembly, you need to take off the bottom panel and repair or replace the door spring or cable.
Jun 04, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
Maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool dishwasher du915PWP leaking
Leaking Dishwasher
heatman101
hk
Nov 07, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Our Maytag dishwasher model MDB4000 leaks from the door, but not every use. The leak started just on the left corner, but now sometimes leaks from the middle. The diswasher is 12 years old.
Usually this is caused by a bad door seal.
It can easily be removed and replaced.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Maytag MDB6000 Dishwasher
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Mar 07, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag Dishwasher 2 years old leaking
open the door of the dishwasher and check the seal. It may have just gotten worked out of place or it could be deteriorated enough that you will need to replace it.
Dec 31, 2008 | Dishwashers
Dishwashers Logo
265 people viewed this question
Top Dishwashers Experts
