Question about Panasonic TH-42PZ77U TV
I have a panasonic th42pz77u. 1 1/2 years old. power led light is blinking 10 times and repeats. No sound...no picture. Any solutions? Tried the unplugging and plugging in again....no go. HELP!
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
SOURCE: 10 blinking light.
It is called mainboard and is the one where you plug your video (HDMI,component) cables if you want to order a new one you need your product code, it is located in the back of the TV, same place as the serial number.
Posted on May 27, 2009
SOURCE: 42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Posted on Jul 25, 2009
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
Oct 12, 2011 | Panasonic TH-42PZ77U TV
Mar 20, 2011 | Panasonic TH-42PZ77U TV
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Feb 16, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Dec 16, 2009 | Panasonic Televison & Video
Oct 31, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Aug 15, 2009 | Panasonic TH-42PX60U Television
Dec 31, 2007 | Televison & Video
1,802 people viewed this question
Same thing, 10 blinks and nothing else. Also had it for about a year and a half. WTF over?
