Question about U.S. Robotics (SPORTSTER0484) (sporster0484) Modem
My Mecer M288 Laptop was not booting to windows and because my CD-ROM is bad, i removed the 2.5 HDD connect to a desktop and format, loading a new windows and it works on the desktop. but when i put it (HDD) back to my laptop it's not booting to windows, it hangs after BIOS page and even trying Safe Mode it stops at a point. it is not just getting into windows.pls, i need a solution(s)that works. thanks and God bless.
2 Suggested Answers
  • 240 Answers
SOURCE: My US Robotics USR5461 Wireless MaxG router needs
Considering the frequency you have to reboot the router to get it to work may indicate a glitch with the WAN gateway.
I recommend fully resetting the router and setting the wireless network up again.
You should be able to reset the router using a pin and sticking it in the pin hole on the back of the router near the power source.
Posted on Mar 30, 2010
I have an old desktop DELL optiplex GX50 that I forgot the win password . I would format with new OS , but the CD-ROM driver could not read the CD " boot problem " . I modify within the...
i bought.a new dell laptop. Modle-N4010. It's battery is not charging but this is working when attached the adapter from theswitch otherwise it is not me.
Aug 25, 2011 | Dell Optiplex GX50 Intel Desktop PC -...
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
I have IBM thinkcentre 8172. I try to reinstal windows XP. But when the pc restarts, it can't complete the instalation because it can't read from CD. This is not the original DVD/CD rom. When i remove the...
If your CD-Drive is IDE and you have IDE HDD you need to remove or set correctly jumper on the back of CD-Drive. I think by default it's setup to be Master, and HDD also Master, so you need to give somebody Slave priority neither HDD/CD
Apr 19, 2010 | IBM NetVista PC Desktop
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
Can u help 2 format the laptop
Before you do begin to format you laptop, backup first all the data files in your laptop. Second, provide the Operating System  you want to install in your laptop. Either Windows Vista or Windows XP. Both windows you can partition the HDD their before install begin. Make sure to set the first boot device to CD/DVR ROM in CMOS setup so it will boot the OS CD/DVD you inserted in the ROM. Good luck!
Dec 31, 2008 | Computers & Internet
How do i format my novatech B750
Just use a bootable CD and boot up with it, you'll come to a stage where you're asked to format your HDD.Or bootable flopy disk, when in command prompts you type format e: and press enter Or you could remove the HDD and use a external USB casing and use other PC to Quick format your HDD. Note:If you're trying to format your Laptop HDD, I will suggest that you get the all driver information for the hardwares before installing a new operating system. Because when new fresh installation is done you will be asked for the drivers for CD-rom, key board etc...
Nov 13, 2008 | Computers & Internet
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Sep 26, 2008 | Computers & Internet
U.S. Robotics (SPORTSTER0484) (sporster0484) Modem Logo
239 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
