Question about Garmin Nuvi 660 GPS Receiver
Garmin c330 freezing
I have had the navigator for 2 years. It had fallen off the windfield many times in this duration. After the last fall, it keeps freezing. I can power it on, and it will work until it locates the satellite and starts to show directions. Once it is in that mode, within 1 minute, it will freeze, and I have to reboot it. I powered it through the USB with my laptop, and it did not freeze for more than an hour, but it wasn't connected to the satellite during this. It seems like once it connects to the satellite, it freezes within a minute. I would be greatly appreciative of any help I can get to fix this problem. Thanks.
  • ramanna Oct 04, 2007
    I am happy to say my problem seems to have been solved. I found 3 possible solutions during my search - may need to try all of them to see if it works.
    1) Reset by pressing the button under the faceplate. (Did not work for me).
    2) Master reset - switch off the unit and press on the right bottom corner of the LCD and switch it on. Release the power button when it powers on, while pressing on the R lower corner. This is supposed to erase all prior data. I could not master reset my unit, for whatever reason.
    3) Software update:http://www8.garmin.com/support/collectio...
    If you are a windows user you will want software version 2.4.1 as of
    April 3 2007. This worked for me.
    Thanks.
I am happy to say my problem seems to have been solved. I found 3 possible solutions during my search - may need to try all of them to see if it works. 1) Reset by pressing the button under the faceplate. (Did not work for me). 2) Master reset - switch off the unit and press on the right bottom corner of the LCD and switch it on. Release the power button when it powers on, while pressing on the R lower corner. This is supposed to erase all prior data. I could not master reset my unit, for whatever reason. 3) Software update: http://www8.garmin.com/support/collectio... If you are a windows user you will want software version 2.4.1 as of April 3 2007. This worked for me. Thanks.
Posted on Oct 04, 2007
SOURCE:
C330 garminstreetpilot not working
hey man your prob is so simple just go through this
1.connect your device to computer
2.go to my com
3.right click on your device
4.click format
5. then restart it now its time to update driver
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer a
Nov 18, 2007 | Garmin StreetPilot C330 GPS Receiver
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem?...
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Sep 06, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 GPS
Hello, I have had 7 Garmin units and 4 of them where streetpilots like yours.
You can try a reset of the unit. This will restore the unit and you might loose any favorites etc that you have stored. Here's how you do a reset.
"With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on."
Try this and see how the unit works. If it still gives you the same problem then your unit needs repair. I have sent in at least 2 units to Garmin for repair in the last 2 years.
Thanks
Feb 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 Navigation quirks
did you check the avoidance settings.....possibly you checked highways and the GPS is avoiding them
Nov 30, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
2,076 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
