Question about Panasonic PV-DV900 Mini DV Digital Camcorder
PV-DV900 - Blank Screen
I was in menu mode when my LCD went totally blank. Everything else seems to work fine through the eye piece. Did I disable the LCD screen or is repair needed?
5 Suggested Answers
SOURCE: LCD Screen goes blank after opening up
I actually have several of these cameras and have seen this happen many times with this model. The ribbon cable that goes from the body to the LCD tears in the same place in all of my experiences. If you look at the hing area, you can see the black coating on the ribbon cable between the body and the LCD. The top edge of this cable tears right where it enters the LCD component. If it works when only 1/2 way open, it's just a matter of time before it totally stops working...the damage has already begun. A replacement LCD runs >$100. Instead, I search e-bay for parts cameras. Just make sure that the description doesn't say that the LCD is bad.
Taking apart the camera isn't all that hard. Start with the e-bay parts camera just in case something goes wrong. Take off the lens cover (the lens actually stays attached to the camera for this entire fix) by removing a screw on the bottom, one just under the eye piece, one inside the LCD door area (near the top), and one inside the tape area...the one closest to the front of the lens. Then, the lens cover slides forward. Once you get it moving forward, extend the eye piece and the lens cover comes right out.
The 2nd step is to remove the LCD. The easiest fix is to remove the entire left side (LCD and SD flip cover). This is done by removing the 3 screws on the bottom (careful, 1 is smaller than the other 2), the screw in the battery area, a screw near the front of the lens, and 2 screws near the top (one above and 1 below the lens). Once the left side is free, tip it forward, exposing the 2 ribbon cables. The larger one is the LCD. Disconnect it by simply flipping the grey bar where the ribbon cable connects to the body up. The ribbon cable should come out with no effort. The other, smaller ribbon cable is the speaker and the "LCD is Open/Closed switch". Be careful with this one. Hold the white connector in place against the body (I apply pressure using a small, flat screwdriver). Pull the ribbon cable out of the holder at the body with your fingers (it should require only a moderate amount of force). If the white cable connector comes off with the cable, you're in trouble...the wires are extremely thin and difficult to get back in the right place...but it can be done.
Once you've removed the left side portion, do the same with the good LCD. Reconnect everything in the reverse order. I use a small needle nose pliers to put the small ribbon cable back into the connector. The larger one just slides in with little to no effort. Lock it in place by tipping the locking back back down. Once you've connected these 2 cables, you can carefully put a battery in and test that it works. If all goes well, remove the battery before continuing to put it back together again.
When you're done, put the parts camera back together again and keep it. You may need it for the lens assembly (I've had grease inside my lenses at times and the front lens can scratch easily, so a replacement is good to have around).
I've tried replacing just the ribbon cable, but getting it out of the LCD isn't worth the effort since finding a good cable usually means that you've also found a good LCD for the above proceedure.
You can find the repair manual complete with exploded views at http://www.eserviceinfo.com/download.php?fileid=27179.
Posted on Mar 06, 2009
  • 98 Answers
SOURCE: I have Panasonic PV-G35 Camcorder. When I
Your flatcable between the camera mainboard and the LCD display is cracked. In the hinge is the flatfiol cracked.
When you want to fix this and you are very accurate you can do it byyourself otherwise you must send it to an repairshop for holland you can contact Rotronica to solved the hardware
Posted on Apr 16, 2009
omtronixom
  • 172 Answers
SOURCE: White LCD screen on panasonic PV-GS320
LCD cable is damage so that lcd is white it need to replace
Posted on Mar 02, 2010
Davidivory1
  • 338 Answers
SOURCE: I have panasonic PV-GS32 camcorder. The lcd was
It does look as if your LCD screen is dead, they are not cheap to replace, but you could pop it in to your local Camera shop, they will mostly be glad to help you.
Posted on Jun 16, 2010
Canon Rebel EOS T3 - camera has power but there is no LCD display whatsoever.
Has the camera been dropped or had a liquid spilled on it? Sound like a circuit failure. However, if it has been dropped it may indicate that one of the flexes has come out or the little flipper on the flex connector has popped up and the connector is not working.
Apr 28, 2013 | Canon Eos Cameras
I have a Lumix DMC-FZ30 which I bought in late 2006. my problem is the LCD screen has gone blank, ( all white). The eye-piece still works, but because of my eyesight it is difficult for me to read the...
Hello Frank! Welcome to FixYa!
If LCD screen has gone blank but eye piece still works best and as you told that you are unable to read the settings then just follow the given steps to reset the Camera
First of all, Turn on the camera. When the camera is turned ON, Press MENU button, Then Press right Key. Now you are here on Settings, Now move front dial to switch pages of settings to 3/4. Here you have to keep intention that you have to move front dial to three times because you have yo move to setting page of 3/4
Now you are here on settings mode where first option as RESET, Now Press right key and the MENU key, It will rest the camera to default settings.
For more details, i am providing you the manual of Panasonic Lumix DMC-FZ30 Digital Camera,To download manual CLICK HERE
It will help you alot, You need Adobe Reader Software to open this manual, If you don't have download it then you can open this manual. It will provide you in all the operations of Panasonic Lumix DMC-FZ30 Digital Camera.
I hope you have clear picture in your mind. Don't hesitate to let me know if you have some confusion.
Sir, If you find my service helpful for you the your Rating as FIVE STARS and your Words of appreciation will be esteemed.
Thank you for taking my service and for using Fixya
Concerned: Muhammad Uzair
Dec 13, 2011 | Panasonic Lumix DMC-FZ30 Digital Camera
Pv-l453d no picture from lens to lcd blank screen ?
Your device has the option buttons on which to select recording by observing the process from the user observation scopes. One option only could be observed at the recording session. On the other hand, disabling the option of observing a recording session on the scope lense automatically displays the recording session on the visible lense LCD screen area.
Manipulating the Camcorder is from the option buttons located along the sides of the camera. A switch on the menu area should make that experiece achievable.
Dec 02, 2010 | Panasonic Palmcorder PV-L452 Camcorder
Blank blue screen nano.
  • First of all do a reset by holding down the Select and Menu buttons.
  • When it's restarted it if it hasn't solved it press and hold the Select and Menu buttons but as soon as the screen goes dark press and hold the Select and rewind buttons. This puts the iPod into diagnostics mode.
  • From there go to 'IO' on the list using the wheel and Select then to Display and keep clicking select as it goes through the different colours and graduations. Hopefully you see them all
  • when it comes to the end it will ask yo to press Menu, so do that.
  • Click Menu again and again until you see reset at the bottom of a list. Go to this and select it.
  • It will now reset and all will be good in the world.
If that hasn't fixed it then it's likely the ribbon for the LCD has become dislodged or damaged. If it has, let me know.
All the best
Sean
PiDigital
Nov 29, 2008 | Apple iPod nano
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD monitor is blank
Canon would have to fix this for you. The fault may be the screen itself, or the LCD viewfinder drive IC on the camera's circuit board. In this case they will replace the circuit board.
Jerry G.
Dec 09, 2007 | Canon PowerShot G3 Digital Camera
SONY DSC P100
Seems like something is crushed internally a connector perhaps- A repair manual -Huh! They don't even repair them. Live with it or buy another But try Sony customer support- you will see what I mean
Aug 11, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Panasonic PV-DV900 Mini DV Digital Camcorder Logo
53 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
