Question about Dual Electronics CECT P168 Cellular Phone
Can't get into my i9 phone
I just bought an i9 phone and the touch feature is not working.....when i touch the screen nothing happens........HELLLLPPPPPP
  • 193 Answers
Send it back, these phones are COMPLETELY worthless wihout the touch screen. the person i bought my phone was always happy to helpme out, hopefully yours is too.
Posted on Apr 23, 2009
I have problem with my sci phone i9, the touch screen won't reponse, if i try few time I just got glass broken sound with glass broken image and sometime I got shutter sound with lighter image please help...
hey man i have the exact same problem. i only had it for a couple of hours and the touch screen feature wont work. well u got to expect that from a china made phone.
Jan 04, 2010 | Dual Electronics CECT P168 Cellular Phone
Annoying clicking sound with my new cect i9 3g
turn off the lock feature for the screen settings/security setup/autolock keypad. seems to have worked for mine but bummer not being able to lock keypad.
Jul 27, 2009 | Dual Electronics CECT P168 Cellular Phone
Sci phone disabled touch screen
Hey.. The problem with the i68's and i9's (Or the other Sci versions of the CECT's is the flex cable connecting the digitizer to the mainboard.. It's a easy fix, and will cost you about $8 on Ebay.. Look for a replacement touchscreen for your model and order it.. then, google the phone model and find the directions on taking them apart.. I have successfully repaired about 50 of them so far.. :)
Hope that helps!!
May 14, 2009 | Cell Phones
I just bought an I9 from a private dealer Screen is not working
if its still under warranty you need to send it back. this phone is completely useless if the screen breaks. they offer repalcement screens for about 25 bucks, but you have to tear the phone apart and solder in 4 points onto the new touch screen. i broke my touch screen and after seeing who tiny of an area there was to solder on i gave up and bought a new one.
Apr 08, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
HOW CAN i FIX M I9 phone/
is it stuck..like the slide feature wont let you slide to get to the main menu??? Mine did this and it lasted for almost a day..i had top take the battery and sim card out and keep putting them back in and keep turning it off and on and eventually it became unstuck. and has worked since and not gotten stuck..if its not that then let me know..also
Jan 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
Cect I9
how can I download music and videos on my i9 phone
Oct 30, 2008 | Cell Phones
Dual Electronics CECT P168 Cellular Phone Logo
213 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
