Question about Boating
I have a damaged Microphone cord to an Icom 304 VHF radio. These wires are very fragile and I doubt if they can be soldered effectively. I have 50 years experience with ham radio and have soldered light wires but this is too small. Can a person buy and install a new mike from Icom? Part Nr.?? Knot-On-call
    Brigadier General:
  • 5,158 Answers
Start here... you can get the brochure for the radio... it should list the part number for the mic
http://www.icomamerica.com/en/support/default.aspx
Robert
VE3 ***
Please take a moment to rate this solution.. thanks
Posted on Apr 21, 2009
IC-M504 with a rear panel microphone jack-- what is the pinout?
ICOM or even HRO may be able to provide you with a schematic for that pinout.
Jun 04, 2012 | Icom IC - M504 Black Submersible PLUS...
On the ICOM M604 will not receive the weather channels, will receive other close radio's.
Hi!
This is almost ALWAYS caused by a problem (a short OR an open) in the coax cable from the VHF radio to the antenna. An easy way to check is to JUST insert the PL-259 connector into the socket of the radio, making sure that ONLY the center pin is making contact with the socket. If the weather channels come in clearly, then it's usually an easy fix. Simply check the connections at each end of the coax, looking for a poor center pin solder connection or perhaps a bit of the ground braid is shorting out the center lead. A magnifying glass is a great tool to spot problems.
If the coax proves NOT to be the problem, then the fault is likely to be in the radio itself and is probably a bad solder connection where the antenna chassis mount attaches to the PC board.
Hope this is helpful.
Good Luck!
Jan 09, 2011 | ICOM Informatique Icom M604 Vhf Marine...
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
When using the OPC617 external cable, what solder pads need jumpered for PTT and mic audio?
To use OPC-617 option cable:1- open your CS-F100 Rev 1.7, read your radio.2- click on Common >> Expert >>EPTT/FTSW change to EPTT, 3- On the main board , look into the left side of the board you see pad D, solder ittogether, if you use pad F, you shou.ld put a 47K ohm resistor.You can follow this link for your pin out connection.http://www.two-way-radio-tools.com/icom-mc1700-mdc.html
and download ver sion Rev 1.7 from herehttp://www.two-way-radio-tools.com/icom-softwares.html
HP
Jun 04, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
Can the Microphone be replaced on a ICOM M302 Radio
The MIC is available with the cord from Icom or me (847-746-0100) It is not easy for the novice, it must be routed through the front panel and plugged in to the circuit board inside. Not impossible to do, just tedious. Also, my wild guess is about $50 to buy the mic, so, not worth it if you pay labor!
Jan 09, 2010 | Icom IC-M302 VHF Marine Radio
Icom vhf radio
i have the same unit. i get interferance from my depth finder wire touching the antena wire off the back of the radio. make sure that no wires are touching the antena wire.
Aug 12, 2007 | Icom M302 VHF Radio
Boating Logo
43 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
