HP Pavilion A520n (DW233A#ABA) PC Desktop Logo
Tom Lahart Posted on Oct 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an A520N HP. When I turn it on it sounds like all is working well and then the recovery screen comes up. If I click on full recovery or any other it goes through the process of recovery but then goes right back to recovery screen after it has already done that. Help.
Sandeep Kumar
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Oct 05, 2013
Sandeep Kumar
Expert
Level 2:
Sergeant:
Answers
252
Questions
0
Helped
31428
Points
553
Remove the recovery software it in safe mode.
if safe mode have some issue in open then you need to install the OS again.
4 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jul 11, 2007
SOURCE: black screen when i turn my cpu on hp pavilion a520n
Have you tried all the instructions before. If so, try changing the another video card. Be sure to tight well the card to the board.
Anonymous
  • 4 Answers
  • Posted on Sep 12, 2007
SOURCE: WRONG CONFIGURATION/BLACK SCREEN/HP PAVILION a810n
if it is in warranty i would suggest you to call the hp guys .... if out of waranty please post the exact error message
Anonymous
  • 64 Answers
  • Posted on Nov 17, 2009
SOURCE: HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Anonymous
  • 47 Answers
  • Posted on Sep 01, 2011
SOURCE: I have an HP a520n
1st check the power if power iz ok u hv 2 install the windows
The drive in my pc does not see any thing . i tried downloading drivers from hp and nothing it is an hp pavillion a520n
From the manufacturer's web-site: http://support.hp.com
enter your specific model-number, and you'll be directed to the available "downloads" for your computer.
Or, purchase a set of "System Recovery CD/DVD disks" from HP, and reinstall Windows. That set of disks will install the correct drivers for your hardware.
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
1helpful
2answers
How much total memory will a HP a520n desktop computer hold. One source said max 1 gig yet another source said max 2 gig, which is correct.
Go to crucial.com and have them analyze your computer. They will tell you you can use 2gb, no matter what HP says, and it does work. I just went through the same thing. Saved me from buying a new computer because 1gb wasn't cutting it and I originally thought that was the max for a a520n. Not true. I do suggest going to HP and getting the Bios update from 2005 if you haven't already done that. My a250n runs great with 2gb ram, replacement 500 watt power supply, GeForce 6600gt GPU, and Audigy SE sound card. With optimized paging file and routine disk cleanup this thing still runs well enough to have a few years left in the old girl untill every new program requires dual or quad core 64bit technology and Windows 7 or above.
2answers
Black screen when i turn my cpu on hp pavilion a520n
Well, in the second (Gege) case you have a bad windows. Repair using a recovery CD (one most likely came with your comp). Whyme, take it in for repair; someones been messing with your BIOS.
A520n will not start up
It defiantely sounds like a motherboard issue, however, if you still want to test the power supply, switches and everything else, check a local radio shack or look on www.newegg.com for the tools to do so. If it does come down to be the mobo that needs replaced, contact me via e-mail and I will give you more info on how to find a compatable board. [email protected]. Subject line motherboard FixYa
2answers
3answers
Are you working on battery without connecting the laptop to the mains power ? Please put the laptop on adapter power and recheck. Rajesh
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
