Question about Philips Televison & Video
Hissing noise from Philips 42PFL3603D/27
My Viewstat 2000 Ultra cable box is connected to my Philips42PFL3603D/27 through the component connection Y,Pb, Pr,. When watchingsatelllite tv on amazonas it makes makes aloud continuous hissing sound that dosen't stops until I take off thetelevision for 10 sec and puts it back on, only then the noisestops.After a while it repeat s itself, sometimes it takes a long whilebefore it makes the noise again.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Turn on the Viewsat 2000 first and after 20 seconds, power on the Phillips42.
Posted on Aug 01, 2017
3 Suggested Answers
  • 2326 Answers
SOURCE: Hissing.
If the hissing noise is from the LCD, it could be from the power supply due to failing capacitors. This noise is generated when the TV is trying to compensate for the lack of voltage/curent requirements.
Posted on Nov 04, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: connection for y pb pr cables
The color-coding used for the RCA connectors is nearly universal:
  • composite video - yellow
  • audio - red (right channel) and white (left channel)
  • component video - green (Y), blue (Pb) and red (Pr)
Also, these jacks are normally labeled in print as well, although it's sometimes hard to read the text on some equipment.
Match the connectors on your converter box to the corresponding connectors on the TV. If your converter box was one purchased with the $40 US Government coupon, it may not have the component video outputs. The only coupon-eligible boxes are the most basic models, and they sometimes have only RF (channel 3 or 4) and composite video outputs available.
Posted on May 03, 2009
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
Nov 29, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Philips 42PFL3603/F7 picture jumpy
Simple Solution. I have an almost the same TV and if you want it to stay in one format press the FORMAT button on the remote. I am pretty sure it is somewhere on the top right.
Feb 16, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
42PFL3603D/27 TV was dropped or hit and broke the tv screen upper righ corner. Tv works, has spiderweb look on screen
can't be fixed becase the entire panel is broken. it is cheaper to replace, because wit labor, parts, ect it would be to expensive
Jan 22, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
What is the remote control code for philips 42pfl3603d lcd tv
Hi - I had the same question and found it here:
www.universalremote.com/resources/pdfs/UR2-CBL-CV04.pdf
Some TV brands have multiple codes associated to it. You must try each one individually until one of them does the job.
This worked for me beautifully on a brand spanking new Philips 42'' LCD.
Jan 02, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Televison & Video Logo
262 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
