Question about Kitchen Ranges
Dual element on ceran top will not turn off kitchenaid ykesc307hw4
  • TJAY Apr 21, 2009
    so should I take off the cover and replace the switch or disable until I cxan get a new part for it, and if so is there a schematic I need to use? Tal
    Scholar:
  • 126 Answers
Problem should be in the switch that activates either inner or outer burner selection.It is the only source that makes selection possible
Posted on Apr 21, 2009
  • Brent  Reddick
    Brent Reddick Apr 21, 2009
    Replacing switch is just plug it in the same way, with it unplugged. If you can use other elements to cook on without operating that one until it is repaired then it isn't a safety hazzard. Probably would be fine to use it as is just would be safe and leave it alone until repaired
Schott Ceran. Why doesn't oven work?
Might try heating element in stove
Oct 03, 2015 | KitchenAid Kitchen Ranges
How to replace element in KitchenAid KECD806R
I've replied to your other post as well. Please regard that answer :)
May 17, 2014 | KitchenAid KECD806R 30" Electric Cooktop,...
I just moved to a fully furnished apartment. How do I turn off the schott ceran cooktop. Both knobs are already pointing to zero but one of the lights is still on.
This cook top light may stay on until the heating element has cooled down,
This is a warning that the top is still hot to warn you so you do not get burnt.
Feb 05, 2012 | Cooktops
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Ceran stove top will not unlock.
Unlock Kitchenaide Caren stove top
Oct 13, 2009 | KitchenAid Cooktops
Dual element burner not working
You have to use a voltmeter and test the voltage where the wires connect to the element. If you have voltage (probably 240volts) then the switch is good.
You then remove the element, and check it with an ohm meter to verify that the element is open.
Sounds like the switch to me, but you have to check it
May 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Top element only stays on high
The trouble would be a failed infinite heat switch. This is the adjustable switch you are using to set the element to low, medium or high.
**Use extreme caution if you are making the repairs yourself.....Turn off circuit breaker and verify power is off with a meter. 240VAC is present at the switch. In addition, the glass top and elements are very fragile.
Apr 28, 2009 | KitchenAid Kitchen Ranges
One of the dual element not heating up on a smooth top electric range
If this section was working before then it is either a defective switch or there is a burnt out section in the heating element - more often than not its the latter - the heating element would have to be replaced
Regards
Sep 22, 2008 | KitchenAid Kitchen Ranges
Kitchen Ranges Logo
128 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
