Question about Whirlpool Refrigerators
Fridge not draining 'tho hole not blocked
Continually overflowing under salad drawers on base
  • maryrobottom Apr 26, 2009
    as the refrigerator is at the top of an integrated fridge/freezer, it is somewhat difficult to get beneath it!!
Try to look underneath the fridge and see where the obsturction is use a stiff piece of wire or an air compresser to remove to blockage.
Posted on Apr 21, 2009
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
Water gathers in salad boxes
Hi,I found out that there are two resons for this that I know off.
one the drain hole where the water runs down at back of fridge is blocked,second one is when you put food in the fridge and it gose and tuches the back wall of the fridge it couses the water on the back of the fridge to the veg tray insted of going out of the overflow hole at the back,hope this was some help.
Jul 16, 2015 | Frigidaire Refrigerators
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
BEKO CG964 fridge/freezer - base of fridge flooding with water underneath salad drawers
I had the EXACT same problem. I've just used a wire coat hanger and pushed it through the hole that the plunger couldn't impact and all the water drained out perfectly! Problem solved!
Jul 02, 2012 | Refrigerators
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Fridge drain is overflowing into base of fridge, causing build-up of ice over base, which then 'sticks' the salad boxes to the base of the fridge, making them difficult to draw out. I have to scrape the...
Some insect would have gone into the drain pipe and blocked the outlet for the water to flow and it gets collected inside.
First please clean the drain pipe and remove any block.
Defrost your refrigerator at least once in three days.
Excess ice formed in the freezer chamber will result in less cooling and melting of ice and make it run down.
The above remedies should solve your problem
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
90 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
