Question about HP PSC 2175 All-In-One InkJet Printer
When i print a document, part of the print will be perfect, a couple of sentences, and then several sentences you cannot read at all, its too light or part of the letters are missing - for instance on an email, the heading is perfect, but the message is not - it's either blank or not legible - please help
  • 184 Answers
Follow the steps below to perform basic print quality troubleshooting.
1. Check your paper and verify that the all-in-one has clean, white, inkjet-rated or multipurpose paper in it. In many cases copier grade papers or paper specifically for Laser printers should NOT be used. These papers are frequently coated and are not intended for dye-based inks. The paper container should also have a brightness and weight listed on it. Generally speaking, the brighter and heavier the paper, the better the printout will look. HP recommends papers with at least 90 brightness and 75 g/m2 (20 pound) ratings.
2. Verify that the all-in-one is on a firm surface that fully supports its weight and does not move as the all-in-one prints. If the all-in-one is placed on a desk or other surface that is free to move or shake as the all-in-one prints, the printout will not look as good as it should.
3. Refilled or remanufactured print cartridges will often produce inferior results. HP will not support any print problems that result from the use of remanufactured and refilled print cartridges since their quality is not in HP's control. If you are using refilled or remanufactured print cartridges, replace them with a new HP print cartridge.
4. Print a self-test page from the all-in-one to verify that the all-in-one is working correctly. If the self-test prints correctly, go to Step 3. If the page does not print correctly, verify that the ink cartridges have ink in them. Then, unplug the power cord from the all-in-one, wait five seconds, and plug it back in. Contact HP for assistance if a self-test page still will not print. To print a self-test page, follow the step below:
5. Press SETUP (or MENU ) until " Print Report " displays, then press ENTER .
6. Examine the self-test page printed by your all-in-one.
i. If the colors are correct and the text is sharp and clear on the self-test page, the problem is not the all-in-one or the print cartridges. The problem is the print settings, the file being printed, or the program you are printing from. Continue to step 7 below.
ii. If the colors on the demo page are not correct or are missing, review HP document Printed Pages Are Missing One or More Colors but No Error Message Appears (buu02176) (in English).
iii.If the printout is not sharp or clear, skip the remaining steps in this section and review the remaining information in this document.
7. Try printing the document again but try changing the print settings by following these steps:
1. Within the application you are trying to print from, click File and then click Print . This will bring up the print screen.
2. Verify that the correct printer is selected and then click Properties .
3. On the Quality tab, verify that the correct paper type is selected, and then change the Print Quality setting to Best . Verify the settings on the remaining tabs are correct and then click OK .
4. Print the file you were trying to print again.
i. If the problem is corrected, the problem was the print settings. There is no need to continue troubleshooting.
ii.If the problem still exists, try printing on different paper.
8. Print a different file or image. If you have a file that printed well in the past, try printing that file. Low quality originals will not print very well. Screen captures and images from the internet are often at around 75 dpi. These images are at too low of a resolution to print well. If the self-test page looks good but your image does not, even after changing the print settings, the problem may be the original file. Cheers!!
Posted on Apr 21, 2009
SOURCE:
I have a word document with several paragraphs perfectly done, but when I copy and post to yahoo to send as an email the format changes and there are wide spaces between the paragraphs and sentences but...
Word inserts formatting instructions that many other programs can't read properly and sometimes it helps to copy the text into a program that doesn't like Notepad and then copy it again and past it into other simple programs.
Notpad removes most complicated formatting instructions.
You may also have to tell your Yahoo or other program that the text you are inserting is normal text, because when you insert it it may be in Yahoo's heading mode format.
Oct 24, 2013 | Cameras
I'a computer idiot. I can not figure out how to hilite a paragraph from something i'm reading on the internet and just print that paragraph off my printer
Hi! you may press and hold the left button of your mouse from the start of the paragraph till the end of the last sentence of the paragraph that you want to copy. after you highlight the paragraph, you may press CTRL + C button on your keyboard to copy all the sentences, open a word document, right click on the word document and press paste. this will paste the paragraph on the word document. lastly you may press CTRL + P to print the file. Please make sure that the printer is connected to the computer and is on. Thank you for visiting FIxYa.com!
Jun 05, 2010 | Microsoft Windows Vista Home Premium...
Bottom of letters in document not printing.
it is problem your printer page setup please set defalt or re install printer driver
thanks
xptareq
Jul 30, 2009 | HP Photosmart C4180 All-In-One InkJet...
Printer "out of memory"
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Printer won't print word perfect doucments
try a different pint driver such as a pcl4or5e.
Apr 15, 2017 | Office Equipment & Supplies
Printing on the same line after a few pages printed
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
May 30, 2008 | Epson LX-300+ II Matrix Printer
Printing
try to do a system restore to a date when it was working ok, if still no go, then reinstall the printer driver.
Jan 30, 2008 | Dell 922 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
232 people viewed this question
Clive
Clive
Thomas F. Schneider
