Question about Kenmore 46462 Front Load Washer
Door is open but lock is in the lock position
Kenmore elite he3t MODEL # 110.4597
  • 2 more comments
  • gregvayda Apr 23, 2009
    thank you for your help but it looks as if the plastic piece is broke inside the actual lock i have ordered the part from sears and if you could give me your simple steps to replace it i would appreciate your help. thanks again
    Greg
  • gregvayda Apr 24, 2009
    thanks for al your help i really appreciate all you help
  • gregvayda Apr 27, 2009
    i am still receiving door lock error message. did i do something wrong?
    I am still receiving error message. Am i doing something wrong?
    Sniper:
  • 88 Answers
There is a manual lock release on the bottom of the door latch. Remove the bottom kick panel by removing three 9/32" screws from along the bottom, then reach inside the washer, up to the door latch. You should feel a small plastic tab on the bottom of the latch, pulling this tab should release the lock. If this does not help, you may need a new door latch. If that is the case, re-post and I will list simple steps to replace the latch, if needed. Hope that helps.
Posted on Apr 21, 2009
  • Dan Sharpe
    Dan Sharpe Apr 23, 2009
    To replace the door latch, remove the outer spring on the gray door seal, just use a flat-blade screwdriver to pop it out. Remove the three screws securing the latch. (sorry, I do not remember the exact bit size maybe a T-15). Pull the door seal off the front panel and push aside so you can reach in to the latch. Lift the latch up an inch or two, as it hooks into a small plastic bracket, and pull out the front, removing the three wire harnesses as you do. Reverse process to install the new latch, the wire connections are all unique to each other, so easy stuff there. Some people have issues putting the door seal back on, but it's really not bad, just get the seal seated back in place and put the spring back on one of two ways...1 tuck the actual spring portion under the bottom lip of the seal, hold in place firmly with your knee, and then work it back around with a screwdriver, assisting with your left hand. 2. Stretch the spring out with a needle nose pliers to relieve the tension and then walk it into place by hand. ....Good luck!
  • Dan Sharpe
    Dan Sharpe Apr 28, 2009
    Is it an F-DL? And if so, were you getting that code originally? I didn't see anything about an error code in your original post.
Elite HE3t washer, in the middle of a load, it stopped. it flashes dL, F
door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
Sep 03, 2011 | Kenmore Elite 45986 Front Load Washer
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
    FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
    Possible Causes / Procedure
    • Door lock mechanism is broken or removed from door.
    • Door switch/lock unit failure.
    1. Unplug washer or disconnect power.
    2. Check door switch/lock unit.
    3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
    Apr 12, 2009 | Washing Machines
    Kenmore Elite washer Locked
    remove bottom panel reach up from bottom to lock area pull the small tear shaped release to open door if water still in tub pump may be plugged to clean turn handle on pump to left and pull out trap and clean ..after dipping as much water out as possible
    Jun 26, 2008 | Kenmore Elite 45986 Front Load Washer
    Unlock the control panel to a kenmore elite front loader
    to unlock the controls
    select and hold drain/spin for 3 seconds until the control locked status lights turn off.
    Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Kenmore 46462 Front Load Washer Logo
    147 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
