Question about Whirlpool Calypso GVW9959K Top Load Washer
Replacing timer on a whirlpool lsr8433kq0
Machine shut off during rinse. If you jiggle the timer sometimes it will start again but shut off within a few minutes. I think its a bad timer. Can someone confirm and can I replace it myself?
Thanks Garrett
    President:
  • 331 Answers
Garret,
Yep... it sure sounds like a failed timer. I looked it up for you, the part number is 3948852. You can find it online or see if you can get one from a local appliance parts retailer.
SG
Posted on Apr 21, 2009
  • Tracy Farrell
    Tracy Farrell Apr 22, 2009
    I forgot to mention... Yes, you can definitely replace it yourself. It's a snap.
    UNPLUG THE WASHER! The timer knob simply unscrews, then the timer knob "skirt" slips off the timer shaft. Under the skirt, you'll see two 5/16" screws that mount the timer to the control panel. Now just unplug the old timer from the wire harness, plug in the new one, mount it to the control panel and finish the rebuild! Total job time is ~ 20 minutes.
    Watch this video to learn how to gain access to you washer.
    That's it! All you need to do now is rate this solution as "FixYa"
    SG
Washing machine washes rinses and spins but not automatically
sounds as if your timer has gone out of the unit. The timer controls the cycles.
Jan 28, 2012 | Whirlpool Washing Machines
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Whirlpool washing machine not completing cycle
Don't gonna be the timer
If your washing machine gets stuck just before the rinse, than its gonna be the lid switch
May 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Machine is not draining - is not the timer this time.
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise?? problably not. machine doesnt think lid is closed so for safety reasons wont spin/drain replace the door switch assy part num 3949237
Mar 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
432 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
