Dryers Logo
Anonymous Posted on Oct 04, 2013
THE DRYER WAS WORKING AFTER I REPLACING THE CORD.. IT WAS RUNNING REAL GOOD AND HOT FOR 2 LOADS THEN ALL OF A SUDDEN IT STOPPED WORKING. WHEN I TURN THE DIAL ON YOU CAN HEAR THE MOTOR NOISE BUT NOTHING HAPPENS WHEN I PUSH THE START DIAL
Pat Thompson
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Oct 04, 2013
Pat Thompson
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
9661
Points
41
2 Related Answers
Anonymous
  • 64 Answers
  • Posted on Mar 12, 2010
SOURCE: My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Anonymous
  • 618 Answers
  • Posted on Dec 03, 2010
SOURCE: I was using the dryer
First check the 30 amp fuses in the panel. Next check to see if the belt is broken. Next short out the small thermal fuse on the heater housing and if the dryer starts replace it .
Service Cord message
Check for a good ground, Appliances now days will not run without proper ground because of the electronic boards
The Dryer is running too hot (red hot) and not turning off or running it's cycle.
You want to do a few things to correct this. First make sure your air flow is good. then replace the cycling thermostat. That stat is mounted on the blower housing right next to the fuse:
I recently worked on a dryer that was doing this exact thing and I replaced the control thermostat.
My friend Larry brought it by because it was overheating and he had already changed the fuse once.
I always see the tough or the strange. LOL. Anyway I took the dryer completely apart and cleaned it up real good. Replaced the fuse and observed the dryer with the back off. I watched the heating element and it just stayed on way too long. Normally you can hear the control clicking and observ the element coming on and off. The cycling thermostat has 4 wires. 2 small wires and 2 large wires. The large wires carry the current to the heater element. The 2 small wires are use to warm up the klixon so that it will shut down even faster for knits and perma press items. So what goes wrong? The bimetal inside the control simply gets fatigued and don't shut down no more. The dryer overheats and the fuse blows.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
IT JUST SAYS THAT IT IS A HEAVY DUTY, IT IS PRETTY OLD. IT WILL NOT HEAT, IT SEEMED TO GET REAL HOT ON THE 1ST LOAD THEN NOTHING ON THE SECOND LOAD
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
2helpful
2answers
Dryer is not heating
The following link explains how to troublshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The first step in troubleshooting this problem is to ensure you have the proper voltage at the receptacle. Take a reading across the two hot terminals at the terminal block on the back of the dryer. This is the RED and BLACK wires where the power cord connects. To ensure your safety, please follow these steps:
1. UNPLUG the dryer.
2. Remove the coverplate on the terminal block.
3. Connect your meter leads and plug dryer back in.
4. Take your voltage measurement and UNPLUG dryer.
You should get a reading of 220-240VAC. If the voltage is incorrect, you may have a bad power cord, or a breaker tripped. Check the voltage again at the receptacle. If good, and bad at the terminal - you have a bad power cord. If it is still bad, check the service panel for a possible tripped breaker. Some homes have a dual breaker for the dryer. If one breaker trips, the dryer will only be getting 1/2 the required voltage. The dryer drive motor only uses half the input voltage and will still run, but the heating circuits require the FULL service in order to work. This will give you the symptoms of a dryer that runs, but doesn't heat. If the breakers are set, and bad at the receptacle, you may need a certified electrician check the wall receptacle.
If the source voltage is good, you have a problem in the heating circuits. The number one cause of dryer heat related problems is clogged or poorly installed vent ducting. This causes the dryer to overheat to the point of failure. The common failed part is the Thermal Cut-Out (TCO). The TCO acts as a fuse and if it trips, it must be replaced.
Please read through the link I provided and make sure you check everything, to be sure. If you have any questions, please let me know. I hope you find this helpful.
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 • Dryers
Dryer gets hot and turns off timmer still going,wont restart for approx 20 min
there is a thermal switch it cuts out the heater element when its at temp. also so has a thermal switch that cut out the unit if it gets to hot. there will be two thermal switches or a combined one. it will have 2 to 3 wire on it and is directly connected to the the drum. one of these is the problem the thermal switch is working as its cutting out the unit. to stop a fire.
Top Dryers Experts
john h
