Question about Lenovo IdeaPad Y510 Notebook
Failure to install vista home premium updates, and my Lenovo y510 is stuck in the 3rd configuration stage
My lenovo ideapad Y510 is not able to start windows vista which was preloaded into it when purchased.as soon as it is switched on, fan start running and it gets shut down after sometime without starting...
This sounds like a problem with the operating system. The best way I know to fix this is to wipe the old operating system off and install windows 7 with a full install disc.
Windows 7 Home Premium is more stable and faster than Vista ever was, but will cost $199.99 or so for the full version, or if it's possible to install with the upgrade, $119.99 or so from Microsoft.com.
If your Vista could be started, you could theoretically go to the recovery console and 'recover' it or go to help-> restore and restore to an earlier date where the computer wasn't malfunctioning. However, these options aren't available if you cannot even start windows.
Feb 02, 2011 | Lenovo IdeaPad Y510 Notebook
I have lenovo ideapad Y510 with vista installed. touch inductive panel is not working
Hi drsajidayaz,
Based on your situation. I suggest trying the following steps:
1. Download the updated touchpad driver.You may visit link below for the driver.
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_show_148.html#
2. go to download here then click on IN2THP4WW3.exe
3. after downloading install the driver then restart your computer.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Jan 13, 2011 | Lenovo IdeaPad Y510 Notebook
Lenovo built in web cam is not recognized. I am running vista home premium 32 bit on lenovo model 15303 (Y510). it was working after restaging computer then image from our camera was flipped upside...
Hi aem22192,
1. Download the updated Lenovo Easy Camera Driver.You may visit link below for the driver.
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_show_651.html
2. go to download here then click on IN1CAM22WW3.exe
Hope it helps.
Best regards,
Reyjoshua07
Jan 01, 2011 | Lenovo IdeaPad Y510 Notebook
WEB CAM IS NOT WORKING IN MY LENOVO IDEAPAD Y510 LAPTOP AFTER INSTALLIN WINDOWS 7. PLEASE GUIDE ME.
Hi satyadevbujj,
Based on concern, Y510 camera driver for Windows 7 is not yet released based on Lenovo's support download site. Hence, you still can try updating the camera using the windows vista camera driver. Just go to this link.
--> after downloading, install the driver then restart your computer.
Hope it helps,
Thank you for using FixYa.
Oct 21, 2010 | Lenovo IdeaPad Y510 Notebook
I have lenovo Y510 with vista home basic installed. After some problem all veriface,power2go,shuttle centre and Easycapture did not worked. Then i installed vista from recovery cd. Now everything is...
download driver then download eyeline surveillance when it says add camera easycam pops up it works pass it on u have juss been school holla back
Aug 22, 2010 | Lenovo IdeaPad Y510 Notebook
How do I get my Acer 5500 to boot from my uTorrent recovery disc?
Do you have your original recovery media for Vista? Sounds like you're going to have to repair the installation.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Dec 18, 2008 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
Device shows : STK7700D.
http://consumersupport.lenovo.com/lenovo/drivers/list.aspx?CategoryID=134&page=2
Here is the lenovo site for the drivers for you pc. Only download and install the xp driver versions...after which you should be able to update the drivers for the devices that have the yellow color and should not have any problems installing.
You can also check the windows update site...do a custom update and search for drivers...sometimes new driver versions can be downloaded that way.
Hope this helps
Mar 30, 2008 | Computers & Internet
Lenovo driver problem
Check the following location for the drivers for your Ideapad Y510.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=12
The drivers for lenovo y410 will not work for your laptop.
In fact most of the XP drivers at the above link were available since December 2007
Hope this helps.
Dec 27, 2007 | Computers & Internet
Lenovo IdeaPad Y510 Notebook Logo
53 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
