Question about Air Hogs Room Raider Great First Radio Controlled Plane
Air hogs micro hovercraft doesnt work
I just bought an air hogs micro hovercraft and i charged it up and after i charged it up all the lights came on but it didnt work at all. can anyone help me?
  • Miki101 Apr 30, 2009
    I just bought an air hogs micro hovercraft, all the instructions are in french. I tried charging it but no matter in which way or for how long I charge it it only works for about 3 seconds and than turns off.
  • fplqnewc
    fplqnewc May 11, 2010
    Have you changed the switch from charge back to run?
SOURCE: Air Hogs Micro Havoc Heli spins wildly
The same thing happened to me. It turned out that some hair and fibers got wrapped around the tail rotor axis. I pulled the tail roter off and cleaned it out. After I put it back together it worked fine. I hope this helps.
Posted on Dec 30, 2008
  • 30 Answers
SOURCE: air hogs rotor - pulled wires
first just shove the wire back in and try to wiggle the motor back in and it should appear to be untampered and if you still have the box there is a number on the back, you just tell them the rear motor didnt work and they will send you a new one or you can put it back in the box and take it to wherever you bought it and tell them the same thing and then theyll give you a new one if you cant find the number here it is: 1-800-622-8339
SOURCE: How do I charge my Air Hogs Zipper?
I took the cord and put in the slot by the power switch and made sure the Zipper's power was off.
Posted on Nov 07, 2009
Testimonial: "THANK YOU FOR TELLING ME THAT NOW I CAN USE IT AGAIN!"
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
bayyagg
  • 1672 Answers
SOURCE: HAve the motorcycle air hog
Check the motor connection, looks like the wire connected to the main motor is disconnected!
Open ur toy and check on that!
Posted on Dec 01, 2010
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
How long does it take to charge. mine has a problem charging and operating. how do you know when it is charging?
the light on the front of the heli blinks green red green gred then when its fully charged it just blinks green. also make sure the tx is turn to the charge setting which is all the way down
Feb 21, 2011 | Air Hogs Reflex Micro Helicopter
Well the instructions say that I cant leave it in the charger after its done charging. And it doesnt say how long it takes to charge. I have a Reflex.
By rule of thumb, rechargeable batteries, should be charged for 12~14 hours OFF FROM THE SHELF. Then, 3~4 hours thereafter. This has proven to prolong re-chargeable battery's life.
TIP: observe how long the battery last first. so that you'll know when to charge again.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 29, 2011 | Air Hogs Reflex Micro Helicopter
Why is my airhogs microhovercraft not charging and not turning on. THANK YOU.
Right here is the support site. http://www.airhogs.com/#/need_help
This is the place to get help for Air Hogs.
They also have a "community" link which may do you some good too.
Dec 25, 2010 | Air Hogs Micro Hover Craft Hovercraft
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
My Airhogs Reflex is ****!!!!
Aug 19, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Air Hogs Room Raider Great First Radio Controlled Plane Logo
276 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
