Question about Fujitsu Computers & Internet
Fujitsu siemens L7ZA DEAD
My monitor was dead after a powerdown in our house.
I opened it and there was 3 bulbed capacitors inside.
I changed them but still dead when i put the powercable in.
Any suggestions?
Power suply ic number
Posted on Sep 30, 2010
Samsung sync master 798MB plus monitor is dead. Pls give me a circuit diegram
most of the problems of dead monitor is the power supply, check some capacitors inside the monitor, if capacitors puffed or leaked, change with new one. hope problem solved
Jul 22, 2013 | Computers & Internet
Tft
check the power cord, set to the monitor correctly, if still dead, open the monitor, check the power supply module, find some capacitor inside it, if became puffed or leaked change with new one.
Jul 17, 2013 | Samsung SyncMaster 931B 19" LCD Monitor
My lcd monitor model no. L7ZA NOT showing no picture comming & bilnking blue led contenue so plz help me
your computer unit couses the problem. do you try other monitor or computer? try to check the cpu if it is working.
Aug 20, 2011 | Fujitsu Siemens Siemens Basic Line 38B2-M...
Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 12, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu siemens esprimo E3510 PC, screen goes dead at random intervals, PC power light still on, reboots ok sometimes (after pulling power cord)_, then goes dead again
Be sure all fans are working and blow out dust so system can cool properly. If clean, may be power supply or video card. Ensure cables inside are connected properly. Use caution when entering case. Voltages are present so make sure to unplug unit.
May 05, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
My Fujitsu siemens monitor fades after some time
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 10, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Computers & Internet Logo
1,810 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
