Question about Saws
Stuck blade i have tryed wd40,hitting the spaner with a hammer but the blade still wont losen, I cant move the nut that holds the blade in place. I was thinking to trash it ? The tools blade is all over it wont even burn through the wood it needs to be changed. The problem is I can not for the life of me remove the nut holding the blade in place?. The issue is that I can get it to budge and will enough pressure applied the blade spins before the nut loosens even with the blade brake on?? I even tried putting the blade down on a 2x4 and the blade just endes up spinning through the wood before the nut will turn. I have no idea why Over tightened? Rusted?? Anyone have any ideas? I dont really want to spend out to get a new one. Please help! i have tryed to turn the nut both ways just i case
  • 2 more comments
  • r_ianr Apr 22, 2009
    hi, thank's for your reply but the blade is still stuck.the saw is a metabo kgs 255. Is it worth trying to heat the blabe up with a blow torch or some thing? (would it be safe to do that)
    hi, thanks for replying , i dont have a torch hand so i cant try that idea untill the weekend. you can look a picture of the saw on this web site if you want (but dont buy one in case blade gets stuck)
    http://www.transtools.co.uk/store/prod_1...
    if you have any more ideas i would be greatfull. as soon as i try the torch i will post back to let you no if it worked
    thanks again
    hi, thanks i no its a left handed thread i have only hit it the wrong way it try to free the problem,but i will have a look at the manual
  • Samuel Charles Spriggs May 11, 2010
    Perhaps you are turning the nut in the wrong direction. Overhead saw motors (chop saws, radial arm saws) have left handed threads and to remove them you turn them clockwise.
    President:
  • 1,489 Answers
I looked for a picture of this saw -- couldn't find one. When you wrote that you put the blade down on a 2x4 that sounds like a chop saw. In which case the balde is attached to the motor shaft.
A torch is kinda extreme, but if you do it safely & quickly it might work. If the blade is on the motor shaft, you don't want too much heat to get into the motor.
You don't want to heat the blade. Heat the nut only -- the nut will expand more than the shaft and perhaps break loose. I wouldn't heat it more than 20-30 seconds and make sure the flame is directly on the nut. Also make sure all flammable stuff is out of the way (like sawdust).
I wouldn't expect the heating to allow you take it off by hand -- you'll probably have to try all the brute force measures again -- and remember the left hand threads.
Posted on Apr 22, 2009
    President:
  • 1,996 Answers
What kind of saw? (Because Bosch has reverse threads). Here are some instructions for a user of a mitre saw, click here
Sometimes there is a facet on the washer on the other side of the blade that allows you to use two wrenches, one to hold the blade still and the other to loosen the nut.
If not, you can usually use a block of wood and wedge it into the teeth to keep the blade from spinning.(or a piece of plywood). If it's a table saw the nut needs to come off counterclockwise. Maybe you could put a vise grip on the blade and wedge it against a block. Then try some firm taps on the wrench with a hammer, Firm, quick taps.
Or use a long piece of pipe or something on the wrench handle to give you more leverage.
I guess it won't really matter if you ruin that blade, because otherwise your saw is no good.
You may want to replace the nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
  • efs_perpends
    efs_perpends Apr 22, 2009
    Here's a link to the owner's manual for your saw:
    http://www.screwfix.com/sfd/i/cat/pdfs/6...
    You'll see on page 13 that it is a left handed thread, so you've probably been itightening instead of loosening.
    I hope that helps!
Where is the reset button on hitachi chop saw
Posted on Jun 05, 2010
Rill bit stuck
drill in bench screw a little bench hammer and place te drill on the left side horizontal of the bench screw on the top of the claws p the machine hangs free place the little bench hammer with the point against the top of the claws of the chuck and with a middle heavy nylon hammer hit the bench hammer slowly that you see that the machine is moving ( use of some wd40 or other oil in the chuck will helping a bit ) it will between 2 and 5 minutes that you have rescued a chuck and "sometimes" also the drill its also depending on the diameter of the accesoires you have used.
Succes
Apr 06, 2014 | Makita BHP452A 18Volt LXT LithiumIon...
The locking nut on my angel grinder is jammed
Look on the nut and see if it is indicated which way it should turn. Put a wrench on it and use a dead blow rubber hammer to strike it while holding the wrench in place. I will warn you this might damage the blade lock if you hit it too hard.
Mar 18, 2012 | Makita Saws
What holds front brake rotors on ,,big nut is off
very common problem, try hitting the portion of the rotor that slides over the wheel studs with a hammer, dont be afraid to give it a good smack, if its really stuck you may have to heat it up first then tap on it with a hammer or air hammer
Jan 03, 2011 | 1998 GMC Sierra
Tire will not come off when lug nuts r removed on front right whe
this is a very common problem rim rusts in place just hit it hard with hammer it should come lose
Apr 12, 2010 | 2004 Hyundai Elantra
Replacing the element in a NEFF U1721 but having trouble
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
Jan 15, 2010 | Neff U1721 Double circotherm Electric Oven
Flat tire will not come off of vehicle
Not to sound like an *** but hit it harder? Theres nothing else holding you wheel on except corrosion. If you put one lug nut on loose and then hit the tire from the back and keep spinning it hitting it in a different spot each time it should fall right off and the lug will stop it from flying.
Oct 20, 2009 | 2004 GMC Envoy
Romoved lug nuts, but tire will not come off. Has
jack up and add another support remove all but 1 lug the remaining lug nut loosen about 3/4 spray around center hub and around each lug nut with a lubricant wait 5 min get a piece of wood and a hammer or a big rubber mallet and start hitting around the back of the tire the wood and hammer ,the wood is to protect the rim hit the wood with hammer not directly on the tire could bend lip of rim should break loose from hub
Sep 27, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Cant get the inner hub off the spline shaft (front passenger side)
i assume you removed the nut that holds the spline shaft on the hub? try wd40 and put the nut back on a few turns and beat it with a hammer
Apr 27, 2009 | Saturn Vue Cars & Trucks
Have a 12 inch tradesman miter saw and can not change the blade
the nut maybe a left handed thread. the norm is righty tight. lefty loosy, try the oposite.
Apr 09, 2009 | Saws
Saws Logo
362 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
