Question about HP Hewlett Packard Officejet Pro L7680 InkJet Printer
Paper feed grabs more than one sheet
I have an HP L7680 All in One and have noticed that when printing the paper feed sometimes grabs more than one page at a time resulting in some pages are printing on two pages. It has "eaten" one page corner & I cannot locate the piece that was "bitten" off but the unit still prints/copies fine. Can you assist?
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Posted on Jun 03, 2009
PAPER WON'T FEED PROPERLY. GRABS SEVERAL SHEETS
You need a seperatin pad, sub pad kit and new feed roller.
May 20, 2010 | HP LaserJet 1100 Printer
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
HP C3180 keeps grabbing multiple sheets of paper when printing.
One thing you can do is make sure you fan the paper before loading it. Sometimes the paper is **** together.
Another thing is your pickup/Feed rollers might be worn out. I'm sure your can find some new ones on HP.com.
Apr 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
My D7460 will not feed paper The screen says load paper face down in main tray.
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Oct 28, 2009 | HP Photosmart D7460 Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
PAPER FEED
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
Dell 922 All-in one ink jet printer paper feed
Jan 08, 2009 | Dell 922 All-In-One InkJet Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP Hewlett Packard Officejet Pro L7680 InkJet Printer Logo
323 people viewed this question
Seeker5211
Seeker5211
