Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set at. Freezer is set at 0 but shows 5, fridge is set at 34 but shows 38. What do I do? thank you!!
  • eileenbre844 Apr 21, 2009
    thanks a lot! :)
  • GE Master
  • 3,361 Answers
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Posted on Apr 21, 2009
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
GE Profile Arctica Model PSS25NGNA CC Hi, I noticed that water was leaking out of my water dispenser. Upon opening the freezer I noticed that everything was thawed out. The doors had been closed and t
you ended with the fan starts to run ? check the coils there should be a fan that blows across the coils sometimes the fan gets to dirty dusty clean that out and make sure that it works it must be running to keep the gases from over heating also clean the coils as will help big time
Oct 22, 2012 | Refrigerators
I have a new GE Arctica refrigerator in a condo I just purchased. Whenever I open then close the main refrigerator door the beverage door pops open. Many times this goes unnoticed for hours. Is there a...
Close the door more slowly.
What is happening is the air pressure does not equalize on a fast close causing the excess air to travel through least resistance.
Apr 15, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Profile Arctica, Air flow fan runs but compressor dont kick in to make anything cold!
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this.
Feb 23, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Food in the freezer on my side-by-side GE Profile Arctica (PSH25MSSA SV) is thawing. Temperature is higher than normal (melted ice cream, etc.) but returns to frozen after awhile. Has happened many times...
It's hard to understand how the refrigerator compartment would be okay, but the freezer is not. The evaporator coils are normally behind the freezer. The cooled air is moved from here to the freezer and refrigerator by the evaporator fan. Is this the fan you are saying is going on and off? Or the compressor fan underneath the refrigerator.
The necessary conditions for proper cooling are:
1. Compressor is running; 2. Compressor fan is running; and 3. Evaporator fan is running.
Oct 18, 2009 | GE Profile Arctica Stainless Steel Top...
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
408 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
