A smell like hot lubricant is coming from the machine while it runs. I can't figure out how to take the back off to get a closer look. KT
  • 532 Answers
Probly the belt slipping,tip backwards a little and look from under the bottom
Posted on Apr 22, 2009
F250 2015 26,000 Squeaking noise coming from rear end crawled under it and the differential was very hot to the touch only drove it 10 miles down the road gas mileage has also gone down to 11-14 mpg
It is obvious that you need to check the rear end. IT may have run out of lubrication. These are not cheap and you would be better off replacing it. The lubrication that they use in those smells really bad. Check for seal leaks at the axles near the wheels and on the cover gasket.
Feb 18, 2018 | Cars & Trucks
How do i clean my stainless steel krups coffee maker before use model kt 611d50
Just run one full pot of cold water through it. Do not add coffee. Then it is ready for use. Caution - Do not make coffee right away because you can break the glass carafe by adding cold water to a hot carafe. Also the hot plate would be very hot too.
May 30, 2014 | Krups FME2 Coffee Maker
Burning Smell from washing machine! Brushes?
2cm seems short for brushes, probably your problem.
Nov 11, 2013 | Washing Machines
Odd smell when plugged in. smells almost like a lubricant or diaper cream. we've cleaned and bleached everywhere we can. it doesn't smell unless it is running and it is not inside the refrige
in the freezer behind the back inside wall of the freezer there's an evaporator fan motor that could cause this if you were smelling this inside,there's also a condenser fan motor in the back bottom of the machine that blows when it's running,pull out the machine,remove the bottom back panel and check the fan motor to see if any oil is leaking out of the motor.
Sep 15, 2012 | Estate TT18TKXKQ Top Freezer Refrigerator
NordicTrackl c2300 model NTL12944 bad burning smell
Dear Sir:
You have 4 conditions when burning smell:
1) Very high belt/deckfriction.(Lack of lubrication by maintenance2) Short in the motor.(The same problem maintenance)3) Short in the wiringor electronics.You must have some skill in electricity or electronic or you can cal some service tech.4)Literally cooking the lacquer or cardboard core (on cheap machines) in themotor from belt friction or a drive system,The same lack of maintenance and lubrication.
And recommend that RUN the Calibration Software for easy diagnose and troubleshooting that coming with your treadmill, most of them the instruction step coming from the Hood of motor, and follow the instruction, or use your manual Ins.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
Hi switched my sewing machine on today and burming from piece that goes into machine smells like the motor.
Switch off the power and smell closer to the motor , is you feel the motor was running hot or is still heating up without a movement then it is possible that the motor is faulty.
Make sure there is no friction on the mechanism or the drive. If so remove motor and test on direct voltage to confirm if there is any issues with the switch.
Aug 19, 2011 | Riccar R552
Hi my washing machine has started to smell of rotten eggs its only 6 months old and dont no what the problem could be
Possible that the smell is coming from the motor/inlet valve/ pump or the capacitor of the motor. so it is important that you need to have a closer observation to find the source of the smell.
Sometimes it can also be due to drain block and so the dirt accumulation could be stinking. If so remove the drain and clean the hose and fitting , back flush the pump and reset.
check for cleaning on the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 13, 2011 | Hoover Washing Machines
Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Nov 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Runs hot and smells
YOUR BELT IS PROBABLY BURNING UP
NEED TO REMOVE OUSTIDE HOUSING AND REPLACE
BEFORE TACKLING, HAVE SOMEONE TILT MACHINE BACK AND CHECK THAT NOTHING IS INTERFERING WITH TENSIONER PULLY
May 26, 2009 | Dryers
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
