Receivers
Problem for Receivers
Generic problem for all Receivers
Receiver shuts down after loud bang
By Nadaholic on Sep 22, 2007
I have a NAD T 773 receiver and it makes a loud sound like "bang" and shuts down completely. Could not operate from remote or front of unit. Red light upper left corner of unit came on. Powered down from front of unit and unplugged for a few minutes. Plugged back in and started unit with the remote and it turned back on. Sound was very bad so turned unit off with remote and back on again and sound was ok. This happened a few days ago for the second time and do not know when it will happen. Unit is enclosed and nothing is around or on top of it so there is good air movement. Unit is still under warranty but a massive pain to unplug all and replug again. Could it be a overheating problem? Should I take it in for service? Let me know what you think.
Thanks
Same Problem
Nov 27, 2007
-   I have a Yamaha Natural Sound AV Receiver HTR 5630. It is about 4 years old. I have never had a problem until a week ago. There would be a loud crackling bang out of one of the speakers and then the unit would shut down. I would turn it back on and sometimes it would be fine and other times it would do the same thing within 10 seconds.
We have had problems with a new microwave we recently bought. Sometimes when we start the microwave it will blow a fuse and shut down everything in the family room Receiver, tv, etc) Could this have fried the receiver? Please help.-   swandizzle
Solution #1
posted on Sep 23, 2007
Somewhat Helpful)
AJ in CA
Rank: Master
Rating: 73%, 14 votes
You said Unit is enclosed!!
Does that mean it is inside something?
Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem.
You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Was this helpful?
Yes
No
Solution #2
posted on Sep 25, 2007
Not Helpful)
LELOT
Rank: Apprentice
Rating: 55%, 1 votes
You said it's bang and shut it off, try also to check the current requirment of your unit maybe current req can't stand for your loud audio..
peace!
Was this helpful?
Yes
No
Solution #3
posted on Aug 11, 2009
Not Rated)
Youjimbo
Rank: Apprentice
Rating: 0%, 0 votes
No fix to this problem. When my T763 had the same symptoms I left it with the dealer who sent it on to service. It ended up being scrapped. So I'm afraid this is the end of your receiver unless your techies are better than the ones who worked on mine.
Was this helpful?
Yes
No
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
Answer
what is the rempote code for the tx-sr603x receiver
Answer
i have 6 speakers c' sw' 2front 2 back. i can not here the c' 2 back. when i sreching with ch chanel... (More)
Answer
Same problem here, red light is on the volume knob. Clicks to turn on but the UI does not light up. ... (More)
Answer
Need a good ir code for Onkyo TX-701 for a DirecTV RC64r remote? Two will work to turn on only,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Receivers:
Top Receiver Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Receiver Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
