Question about Garmin StreetPilot c340 GPS Receiver
New Garmin Streetpilot 340
Immediately shuts off--how long to charge the battery? I drove 30 minutes and still not charged. Also, hasn't been able to pick up correct area--looked for a restaurant in Tucson and got Kansas City.
  • 1 more comment
  • TenderMercy Feb 08, 2009
    I my garmin stopped taking a charge - it's just within the warranty, they are having me send it back - but without the charging equipment - which I suspect is where the real problem is also.
    My Garmin Streetpilot 340 also suddenly stopped charging, I contacted Garmin & they are having me send the unit back for replacement but "without cables or mounts. So if the problem is the cable I'll back at square one.
  • hobomeb Feb 16, 2009
    My Garmin StreetPilot c340 GPS Receiver will not charge with the power cord in my car. The ups connection charges it but it goes dead after a few hours of operation with the power cord connected in my car. I checked the fuse in the power cord and it is good. What now?
I'm having similar problems. When I fiddle with the cord it gets power from the car battery, but only for a little while. I believe there may be a fault/break in the power cord, because it charges just fine on the USB link. I'm thinking of ordering another cord/mount.
Posted on Sep 26, 2007
Garmin streetpilot 2610 does not turns on!!
There is no battery on Garmin Streetpilot 2610 so you have to plug it in !!!!
Feb 10, 2013 | Garmin StreetPilot 2610 GPS Receiver
Battery dead garmin st-finder. Recharge / replace???
if that gadget of yours have a good battery, it would charge, but it does not then better buy a new one. however, pls try checking the battery first, the charger, and the output of the battery. The output voltage should meet the requirment of the gadget.
May 25, 2009 | Garmin StreetPilot C330 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin trouble
Is your battery properly charged?Try replacing it with a new battery iam sure this will fix it.
May 10, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
I hooked the Garmin 340 up to the computer via USB
I strongly recommend you to get it repaired if it is inder warranty because once you break the seal you will loose your warranty service.
And since it is a sealed unit to take it apart you will need some special itype of nstruments which i don't think are available anywhere.
Goodluck..
Apr 04, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
there is a red button on the side of the unit, hold that and the unit will come on.
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Garmin street pilot 330
Take the navigator 2 a repair center, because somethin that new, shouldn't happened unless it hasn't been charged for awhle after being in the box on the shelf
Oct 14, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
116 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
