Question about Cuisinart CMW-100 Microwave Oven
Started to cook then shut off, no screen ligts
Close the door press start and shots off and will not start again,no lights on the screen
Just today, the turntable won't stop turning when the door is closed.
have you pressed the stop button twice when the door is closed to exit the program set for cooking
Dec 17, 2015 | Microwave Ovens
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
My microwwave is not heating,
Hello
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Sharp Microwave oven R-96STM Problem started after powercut. Whatever duration timer is set for, power always stops after 59secends. After pressing START button again, oven runs for a further...
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Sep 07, 2008 | Sharp Microwave Ovens
Help please
Are you saying that it will stop cooking after 59 seconds, but it will resume cooking if you press Start again?
(If not, please reply back and clarify)
If so, this is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Aug 04, 2008 | Microwave Ovens
JVM1650SH01
your problem most likely is in your door aligment there are 2 arms that need to close some door interlock switches inside the unit next time press in on the door hold it and try to start or push down on the door after it is closed and try to start it
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
112 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
noel
noel
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
