How to reset a sony STR-AV920
I was listing to a old album on my turn table and adajusted the balance to the right side because I was getting feed back . The amp quit and lit up all the lights and no sound .
    Problem Solver:
  • 11 Answers
Turn it off, you might have to unplug it and leave it unplugged for 10 minutes or so. It should reset itself. Make sure you don't have a wire short somewhere causing an overload to the Amp. You might have to move the turntable further away from the Amp. It is also important to have the T.table Ground wire connected to the back of the Amp/Receiver. Thanks.
Posted on Sep 23, 2007
    Genius:
  • 1,175 Answers
How loud was the amp up to when it decided to not work?
Posted on Jan 08, 2008
SOURCE:
Need manual for str av920
You may download a copy of the manual here.
May 15, 2012 | Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Sony receiver str-de185
Could need repair of bad solder connections or a cleaning of the pot. With the receiver off turn the balance pot back and forth several times, this may be all you need to do. If it improves a couple drops of wd40 on the pot and a couple more turns should clean it up.
Feb 24, 2009 | Sony STR-DE185 Receiver
I have an old onkyo a-8067 reciever and only the left side speakers work. A while back the right side was fading and now it doesn't work at all. I also have a sony STR D1015 home theater receiver that has...
Fixed the Onkyo. Took apart the balance adjuster and rebent the feather-like things inside so they made contact. Clamped it back together and it works fine.
Nov 26, 2008 | Audio Players & Recorders
Sony STR-DE595 Sound not balanced
HI...
It will need tech service.
Check the Sony consumer site for who can do it.
Aug 15, 2008 | Sony STR-DE595 5-Channel Amplifier
preamplifier or power amp internally but check your signal cables for shorts or breaks,if amp then is internal and needs to be serviced
Aug 13, 2008 | Sony STR-DE595 5-Channel Amplifier
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
Sony Receiver STR-AV920
something bad in load (speakers and thier cabels).
1-disconnect speaker one by one when the fault goen this speaker and it is cabel are guilty.change it .if you did all above and still have a problem you must send it to service center.
Jan 27, 2008 | Audio Players & Recorders
Sony STR DE485 (Audio Video Reciever)
Your problem must be caused by the right channel (rear, front whatever..)side feeding resistor on the power supply.
May 05, 2007 | Sony STR-DE485 Receiver
630 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
