Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
My TB475ss starts and dies right away
When I pull my trigger for my string trimer it stays on for a few seconds and then it dies.
Carb is out of adjustment or gummed up
Posted on Apr 21, 2009
Starts and shuts off
when i turn trimer on i can't trun off [model# wg1502
Apr 21, 2012 | Worx GT WG150 10 in. 18 Volt Cordless...
Gets started but wont's stay running, it dies after a few seconds when i pull the trigger
If you empty out the tank and fish around in there, you should be able to pull the rubber fuel line with the filter on the end of it out. Pull the filter off the line and blow it out, reattach it and you should be good.
lp
Dec 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The tb475ss trimmer will not start.
It is difficult to diagnose a no start problem without the machine being on hand. You need to check for blue spark, fresh oil and fuel and a clean air filter. You also need to verify that the engine isn't worn out and that it has compression. To try and get it to start, remove the air filter and squirt some aerosol type carburetor/choke cleaner into the opening to the carburetor. If it runs a few seconds, that is good and eliminates some of the causes. It may just need a good carburetor cleaning. Post back with results.
Oct 15, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My string trimer starts good but when I give it gas it dies.
you need to get it tuned ...common problem it needs more fuel to get to higher reves...could have a fuel blockage ...as well....
Jul 09, 2009 | Homelite Garden
Difficulty starting Poulan 2250 . . .
hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Jul 03, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My car wont stay running
it could be the fuel pump not working right. you can buy an electric one and put on there and it will tell you right away if your original fuel pump is dead
Dec 29, 2008 | 2001 Volkswagen Beetle
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
1,201 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
