Question about Riso Office Equipment & Supplies
UNABLE TO INSTALL PRINT DRUM
I HAVE A GR3770 STUCK IN PRINT POSITION PREVENTING INSTALLATION OF THE PRINT DRUM
  • 22 Answers
If the drum is out.. just reach in with a pair of pliers.. (Pliers Closed).. and turn the cam that turns the drum until it lines up...Pay close attention to the coupler.. they only go one way. Turn the machine until it lines up. I don't know why they do that ..but sometimes they do..
Posted on Aug 11, 2009
Drum error. slide green tab in each color - Brother HL4040CN Laser Printer
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
Oct 13, 2016 | Brother HL4040CN Laser Printer
Pulled drum out and now it's stuck outside the machine Risograph CR1630/1610
Hello
It seems as if the machine was not in the home position when the drum was pulled out.
The pressure roller is in the up position stopping the drum from entering.
To reset the pressure roller, you will have to remove the back cover, behind the power supply you will see a arm with a heavy spring on it. pull the arm up until it clips into the solenoid.
Once the preasure roller is back down look into the machine, there is a gear with 2 holes in it.
The hole on the left must be in line with the hole in the frame, the hole on the right on the gear must not line up to any holes but show to the exit side on the machine.
I hope this helps you
Regards
Apr 27, 2011 | Riso Office Equipment & Supplies
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Jan 03, 2011 | Riso RZ220 Duplicator
Print unable 32 error message
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
Follow the below link to fix Print unable 32 error message on Brother MFC-9840CDW Laser Printer
http://tinyurl.com/print32
All the Best...
Dec 09, 2010 | Brother MFC-9840CDW Laser Printer
Print unable 32 comes up after a successful print job
Follow the manufacturers recommendations on how to clean the rollers, etc.
Read the users manual.
Aug 14, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to restore my laptop
Did you try to unable your firewall? Maybe this is preventing the problem.Also is your computer set up for the windows program your computer, can download?
Apr 11, 2009 | Acer Aspire One PC Notebook
Unable to install the electrolux slide in electric range
  • Electrolux may have supplied generic installation instructions, failing to account for design differences
  • Electrolux failed to validate the installation instructions against the actual hardware
Jun 23, 2017 | Electrolux EW30ES65GS 30" Slide-in...
Zen cast installation problem
sounds like something is preventing the installer from writing to your registery. Disable all anti-virus/anti-spyware/etc. programs, then try the installer again
Jun 22, 2008 | Creative Labs Zen Digital Media Player
No installation software
My lexmark z1300 worked great on my Hp computer with windows xp, but that computer no longer works. Now I am back on my Gateway with windows 98 and I am unable to install a driver for my printer, I need to print out a very important document from the irs and I am unable to do so. Please Help!!!
Jan 30, 2008 | Lexmark Z1300 InkJet Photo Printer
149 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
