Question about Konica Minolta DiALTA Di200 Copier
Black line appears on copies fed through automatic top loader
Black line appears on copies when fed through automatic top load
  • anista Apr 21, 2009
    Just found the same info in the manual -- did it and it worked great. Thanks so much for your help.
  • 469 Answers
Clean the scan glass, there is lilely a spot or streak on the glass, use a good glass cleaner and soft cloth or paper towel.
Hope this is of some help.
Ed
Posted on Apr 21, 2009
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
When using the top loader to make copies, the copies come out with a line down the whole sheet?
I fixing is verry simple.Open the top cover of the copier(where you are putting the paper you want to copy).There should be two glasses(One big and one smaller wich is under the top loader).You need to clean the little glass from any dirt.Even a small peace of dirt can make a whole line on the paper,beacuse the scanner is not moving,but the paper is.So clean the little glass(wich is next to the big one and the line will be gona.replay if you need any futher help.Please vote if that was helpfull!!
Nov 09, 2010 | Canon PC-D340 Black and White Copier
Black line on copies produced
Take a look at your drum. If there's a green tab on the exterior, move that all the way to the left. That should get rid of the black line.
Jul 16, 2009 | Brother MFC-7440N Laser Printer
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Lines on copies
Paste this link in your browser,you will find relevant information there;
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&prodSeriesId=378056&objectID=c00062809#A3
Jul 14, 2008 | HP LaserJet 3030 All-In-One Printer
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
Konica Minolta DiALTA Di200 Copier Logo
187 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
