Question about Epson Stylus CX3200 All-In-One InkJet Printer
Printing blank pages
My printer is not printing anything at all. I have gone through the process of head cleaning several times but still nothing when scanning nothing prints i am not receiving any error messages i have rang epson who said the heads may be clogged and that i mighy have to get a new printer, is there any way of resolving this. Thanks
  • 6 more comments
  • caracas69 Nov 10, 2007
    printing blank pages
  • Anonymous Nov 10, 2007
    yes.. my epson stylus cx3200 all-in-one inkjet printer will not display my print
    same problem of the 3 .... please send me the answer right away.. i need it right now... thank you very much...
  • Anonymous Dec 19, 2007
    I have the same problem and i replaced ink cartridges. My ink level was showing that the ink was being used but still not printing just a blank paper.
  • marie_cruz Jul 16, 2008
    i have the same problem and if someone can help me i agrre a lot.....
    thanks
  • makeda Sep 08, 2008
    Have changed cartridges but nothing prints out - the monitor shows that the ink is reducing but not on the paper!!! Help!
  • jarwins Sep 12, 2008
    We HAVE changed the cartridge. It is NOT dry. That isn't a helpful answer. Duh we changed the cartridges that is the problem. Could someone give us a real HELPFUL answer please.
  • jarwins Sep 13, 2008
    I am interested in knowing how to know if the vinyl tube is clogged and how to unclog it. Does the solution work to unclog that tube as well? Is there any way to take apart the printing nozzels and clean them manually?
  • 163 Answers
PLEASE CHANGE THE INK CARTRODGES IT HAS DRY
Posted on Sep 22, 2007
    Problem Solver:
  • 18 Answers
The head is most likely clogged. If your a "do-it-yourself" kind then you can click on over to
fixyourownprinter.com and search for your printer and order some cleaning fluid. There is a vinyl tube that is near the printer head that could be clogged as well. It is very hard to remove the crud in there but it can be done.
Posted on Sep 13, 2008
SOURCE:
I have not been using the Brother MFC 465CN printer for a while. Bought and installed new cartridges, cleaned the print head several times (from the printer menu option). But, nothing is getting printed....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 24, 2011 | Brother MFC-465CN InkJet Printer
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
It will not print. It has new ink cartridges..There are no error messages. Print heads have been cleand several times. It will not print a test pattern. It will not make a copy. Only blank paper comes out.
Head cleaning is mechanical process, printing is electrical process. Nothing print out at all? Printer mainboard problem. Lost electrical to head. Usually caused by short circuit at head. Track on aicaxz solution for reference to repair board. Note: if you have experience in electrical circuit, test mounted fuse at board.
Dec 31, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson 9800 is printing blank paper
Sounds like a head issue. May need replaceing
Jun 05, 2009 | Epson Stylus Pro 9800 InkJet Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Printing
Have you been using the printer lately? Is the ink dried up? Have you gone into the printer preferences to check your settings?
Aug 04, 2008 | Epson Stylus 880 InkJet Color Printer
Printer won't print
If you have not performed the exact procedure described on page 12-15 in Chapter 12, Troubleshooting and routine maintenance, of the Users Manual, do so.
Heed the last paragraph of this page: If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Jun 29, 2008 | Brother MFC-3240C All-In-One InkJet...
Won't print(after changing cartridges
blank pages and bad print are not the same problem. Regarding costly ink, a epson printer tech told me once that the secrete to cleaning a bad print head was to run deep clean 7 times in a row and then a head test and it has worked for me several times on other printers (not an expert here, just personal experience).
Additional note, I have seen both cleaning chemicals and cleaning cartridges on the web, example, searching google for one for my printer I would search for cc-bci-6c which is for a canon cyan cleaning cartridge. Don't know if they work but in case it helps.. good luck.
Barry,
Mar 02, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX6400
Blank pages are indicative ofdried ink.
If the printer has not been used for a long time ink may have settled and dried in the heads.
You may need to replace the cartridges (IF they are very old) and run several head cleanings if there is no improvement.
I typicall try to print a few test pages to see if some of the color work.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Nov 11, 2007 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
230 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
