Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Record from television
When i connect my Handycam to television to record programs on tape from it. I cannot see the output on the lcd of handycam. When i record, only sound gets recorded, but picture is not getting recorded.
Maybe your RCA cable is not plugged in correctly
Posted on Sep 22, 2007
SOURCE:
Olevia HD TV has no out put, how do we record tv on our vcr?
If there is no output connection (quite likely) then you can't record TV programs on your VCR
Apr 11, 2013 | Olevia 742I 42 in. LCD TV
Difficulty to record with a sony handycam dcr-trv22
is it able to record audio? are you able to see the indicators on the lcd screen? are you able to playback previous tapes with recording...if you say yes to all of the questions, there is no doubt that you dont have an issue with the lcd screen. the issue that your having is with the ccd imaging sensor. sony has a recall program for this specific model yrs back, unfortunately its already been discontinued and if you send it to them,it will be treated as an out-of-warranty repair.
Mar 26, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
We have a SAMSUNGA LCD TV. We also have a
You indicated you have a DVD PLAYER, not DVD recorder. You cannot record on to a DVD on a player, you need to buy a DVD recorder/player. Unlike a VCR which stands for Video Cassett Recorder which can record and playback video. DVD recorder technolgy much more complicated.
Nov 28, 2009 | Grundig GU19WDT 19 in. LCD TV
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Samsung series 6 LCD no video output!
Try connecting your DVD recorder directly to the source (satellite/cable box) and then to the TV.
Feb 25, 2009 | Samsung TXN3245FP 32" TV
Unable to down load TV programs from my L19W861 Envision Series T
The best way to record is to connect the recorder directly to the source (cable or satellite box) and then connect the recorder output to the TV.
Feb 25, 2009 | Televison & Video
Taping
If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
Oct 12, 2008 | Televison & Video
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
69 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
