Question about Toshiba Satellite Pro L300 Notebook
I have a toshiba Satellite laptop that all of the sudden has started shutting down on me when I am in the middle of something. What could it be?
I have a Toshiba Satellite laptop that keeps shutting down on me. What could it be?
  • Sad Boy May 04, 2009
    I have a toshiba Satellite laptop that all of the sudden has started shutting down on me when I am in the middle of something and restarts again
  • 42 Answers
Depends. When you say it shuts down, do you mean it flashes blue and then shuts off / restarts, or just plain shuts off, and stays off?
If it is flashing blue real fast, then shutting off, here's what you do:
While starting the computer, press F8 as soon as the brand logo goes away, and keep pressing until you get a screen that says Safe Mode on it. Then highlight the Disable Automatic Shutdown option, and hit enter. Use the computer until you get the blue screen. It will give you an error message, followed by a stop code. (0x0000ce or something like that). Get that error code, and bring it back here. I'll tell you what it means.
If it is simply turning off without warning, and stays off, most likely it is overheating. In which case, head to Wal-Mart, go to the computer section where the keyboards are, and pick up a can of compressed air. Blow out the computer right where you see the vent on the side (maybe on back), and try that. If that doesn't work, get a laptop cooling pad and use that. If it still doesn't work, then the heatsink for the CPU needs to be recompounded, in which case take it to a shop. Unless that is you ABSOLUTELY know what you are doing and can do it yourself. IF YOU HAVE NOT TAKEN A LAPTOP APART BEFORE DO NOT ATTEMPT IT WITHOUT A PROFESSIONAL, YOU WILL BREAK IT.
Let me know how it goes, and i'll try to help you further if need be.
Posted on Apr 29, 2009
Toshiba Satelite shuts down randomly
Try reinstalling your windows, or the program you use.
Or, look if its overheating, buy a cooling pad, it's not really expensive and it helps alot.
Dec 28, 2012 | ASUS Computers & Internet
Toshiba Satellite P205-S8811 all of a sudden it shuts down when i try to play games.
Sounds like it's overheating.It's a common problem with alot of Toshiba's.
Nov 25, 2011 | Toshiba Satellite P205-S8811 Notebook
I have a Toshiba Satellite U505 pc laptop that was working earlier today. I was in the middle of showing a video to a friend when it just shut down. I turned it on again and the Toshiba screen showed up...
If that was a video over the internet you may have downloaded a smart virus. ( ie/ tricks the computer in thinking it is safe ). Shut the computer down and restart it in safe mode. F8 or F11 while it is booting up, ( I could never remember! ). Close all residual tabs/web locations and all other programs. Go to the START icon and restart in normal mode. Me thinks that should do it for you.
ash
Sep 25, 2010 | Toshiba Satellite U505-S2940 Notebook
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
Toshiba Satellite P205d S7479 shuts down suddenly when on battery. The battery is brand new.
Try to turn off the laptop
Remove cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert battery and cables on the laptop
Turn on the laptop
Check if the PC still shuts down. If it is, try to connect the power cable without the battery. If it turns on, call your pc manufacturer to replace the battery....
Jun 21, 2010 | Toshiba Satellite A135-S4527 Notebook
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
Toshiba Satellite M-200 laptop refuses to start
I am sorry. This problem is best solved by doing a complete system restore of you laptop.
Do you have the restore disk that came with it?
Aug 10, 2009 | Toshiba Portege M200 Notebook
Shuts down for reason
soundslike it could be overheating, check the system fan and buy a can of compressed air and blast it through the vents and fan systems, hopefully this will resolve the problem
kind regards and please don't forget to rate us
Dec 08, 2008 | Toshiba Satellite 1905-S301 Notebook
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite Pro L300 Notebook Logo
367 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
