My tumble dryer only blows cold but the drum rotates. I think this could have happened because the filter was not cleaned for 3-4 loads and; therefore, the dryer may have over-heated. I have looked for some kind of obvious reset switch but can't find one. I have also purchased a new heating element and fitted it but still get cold air only. My latest theory is that the last 5 mins of the cycle are for airing, i.e. cool air only, and that the timer switch maybe sticking in this mode somehow? Any ideas?
-   I think i have the same problem except i still get some heat out of it and my dryer sometimes has a gas smell to it, if you knwo about this i would certainly be happly. -   J_boy 12
Mar 09, 2009
-   My dryer is working fine, but no hot are. Venting is clean and clear what part do I need?-   bmfiler
Mar 09, 2009
-   I have a Whirlpool Gas Dryer Model #LGB6200KQ0, I am not getting heat. Everything else works, venting is clean? What is it and what part do I need? -   bmfiler
Mar 07, 2009
-   my whirlpool condenser dryer is only blowing cold air how do i reset it-   kev_ibo
Feb 16, 2009
-   I just got a kenmore portable electric dryer and it doesn't eat p all all, but it does tumble
-   Guest
It's call a bad thermal cut-out. You should have a thermal cut-out and a high limit thermostat located adjacent to the heating element (usually mounted right on the heating element housing). They both should read a short or fairly low resistance in the case of the thermostat. If the thermal cut-out is blown it is not a resettable device and must be replaced. The tco is usually sold along with the high limit thermostat. It is HIGHLY recommended that you replace BOTH at the same time. DO NOT attempt to bypass any of these devices either. They are there as safety devices to prevent overheating. You could end up with a fire if you do. Now...with all that said, the tco will blow for a reason. Not cleaning the lint trap will contribute to it, but the big item is the ducting. If the vent ducting is clogged you will experience longer dry times and eventually the tco will trip again. Take the time to THOROUGHLY clean and/or replace your vent ducting from the wall all the way to the vent opening outside. In addition, while you have the dryer open THOROUGHLY clean the inside as well. This includes the air baffle where the blower fan is located. Rule of thumb: if you have lint INSIDE the dryer, it's clogged somewhere. Good luck and I hope this helps you.
The start switch went out so my dryer doesn't turn on. How do I get in there an fix it? I can push...
(More)
The start switch went out so my dryer doesn't turn on. How do I get in there an fix it? I can push the buttton but nothing happens.
I just discovered my dryer isn't heating, but everything else seems to be working properly. It is a Whirlpool MOD# LEN2000PG0. Is there a reset that will fix this problem in the short term? The vent and lint trap are both clean, but my sons have been drying their wet boots in it recently (we got our first snow of the year) , Maybe the drying time is too long and caused the "tco" to go out? Or would it have been more likely that the lint trap wasn't cleaned out properly at some point?
