The wii will not turn on. It's like there is no power to it. I checked the power supply. It's pluged in and the wires are not pulled out of the supply at all. Do I need a whole new power supply?
i havent played mine in a month or maybe longer i dont really play it that offten and now when i want to play it i dosent even want to come on no power or nothing and it sucksi havent played mine in a month or maybe longer i dont really play it that offten and now when i want to play it i dosent even want to come on no power or nothing and it sucks
i have the same problem, had it since Christmas played it maybe 10 times and I just brought a new game and it won't power on. I've checked all the connections and even tried different plugs in the house, and nothing, now what should I do?
AnonymousApr 26, 2009
will not power up at all! even tried a friends power cord still nothing.will not power up at all! even tried a friends power cord still nothing.
I had the same problem. Red light wasn't on at all and system would not turn on. I tried what the other poster suggested--unplugged from BOTH ends for 2 minutes, replugged and BOOM red light is back on.
Previously, i'd tried unplugging each end separately and it didn't work. Thanks for the advice!I had the same problem. Red light wasn't on at all and system would not turn on. I tried what the other poster suggested--unplugged from BOTH ends for 2 minutes, replugged and BOOM red light is back on.
You can't post conmments that contain an email address.
hi make sure the power supply is working correctly there should be a green light or amber light sometimes the power supply will surge out when theres alot plugs pluged in the same circuit hope this helps
is it pluged in
is power bar turnt on
can you check the power supply conector for power
you have to shunt the green wire to a black wire to force the supply on
then use a volt meter to check red wire for +5 or +121 volts
dont remember witch is witch yellow and red +5 and +12
if the power supply is getting getting power from the outlet but not into the pc replace with a new one best of luck bye bye
Make sure the batteries are not dead in the controllers for turning it on.
Next, check all plugs on the console to make sure theyre pluged it all the way if any. Try it again, if it still doesnt work, check to see if your warranty expired yet. Most likely it hasnt. Next call nintendo for support and see if you may have to ship it in. Whatever is wrong with it right now, is nothing that cant be fixed or replaced. You can also try using a different power adapter to see if thats the problem. If its not turning on, or no lights are, obviously not enough power is getting to the WII. Sometimes the fuse in the power adapters plug in can blow, check that and replace it if needed.
To reset the AC adapter you need to unplug it from the wall outlet and the Wii console and wait at least two minutes. Plug it back in and it should come on. If you have it plugged in a surge protector with other appliances, the other appliances may be interrupting the adapter, causing the power to go off.
