Question about John Deere 4020 Gas & Diesel Tractor Radiator
John deere diesel 4039 over heating ... thermostat appears to be working OK ... new water pump has been installed but still over heating ... new radiator has been installed but still over heating ... other than overheating runs great and sounds great
    President:
  • 957 Answers
If the engine is overheating temperature wise that's one thing but if its blowing out the reservoir and your saying its overheating that's another thing. Please let me know which one applies.
Posted on May 29, 2009
What are the correct tappet settings ?
.014" and .018" Int & exh respectively for John Deere 4039 diesel. Hope that's what your working on????
Feb 24, 2016 | Cars & Trucks
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
322 John Deere Overheating. New rad, hose, rad cap. No noise or leaking from water pump, however I may have put full strength coolant in it. Thank you
one thing that you did not list in your list of replacements that could be the cause of your over heat problem is the thermostat.
relace the thermostat.
now as far as the full strength antifreeze goes, it all depends on what part of the world you live in ( hot or cold ). since you will need to drain part of the antifreeze to replace the thermostat - when you go to refill the radiator use a 50/50 mix and you should be pretty close to the correct ratio.
c...
Jan 04, 2011 | John Deere Garden
John Deere 1520 bought used over heated wheN I
The thermostat is there to help cool the engine by slowing the flow enough to let the radiator cool the fluid. I would install a new one, but flush the engine and radiator first. Also are you losing any coolant? Could be a head gasket.
Jul 24, 2010 | John Deere Garden
What is the correct method to install water pump
Hello. Make sure the metal surfaces are all perfectly clean and sanded smooth with emery cloth. make sure the gaskets fit well. if not trim them. Finally if all else fails use some gasket cement to insure a leak proof water pump. This gasket cement is a common item available at most hardware and auto parts stores. Joe
May 07, 2010 | John Deere Tractor 50, 60, 70, ITJD10
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Engine running hot after thermostat installed
This is a Classic Sign of a Dead Waterpump.
Jan 22, 2009 | 1996 Chevrolet Cavalier
John Deere 4020 Gas & Diesel Tractor Radiator Logo
685 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
